btw I’d recommend buying an electric guitar and audio interface(I’ve got a focusrite 2i4, but the 2i2 will do fine), so you can plug it into a computer(attached to speakers or a hifi(go as high or low as you want quality wise there, your choice)). Will allow multitrack recording (google reaper, but you might get a free copy of something cut down with an audio interface). An amp can come down the road if you ever need one. You probably won’t with the above set up.
You’ll need some kind of amp sim to get realistic sounds though, I’ve got amplitube, but there are others.
not the cheapest route to go down, but worth it, if interested in recording and home studios. This is something more you build.
You can get an amp that will work as an audio interface btw, check of blacktar ID:Core amps. i’ve got the 10, decent enough, but you get a better amp for the money more you spend. But it does work as an audio interface. Worth considering if you are looking at amps.
