The SCS frames had very short chainstays. My medium 56cm model has 415mm stays and makes the bike very fun to ride. But, annoyingly the axle, whilst being 12mm thru-axle is 135mm O.L.D. so similar O.L.D. to the 9mm QR axles, this meant finding a spare wheelset to fit was a problem. The non-drive side hub shell needed its disk brake mount shifting over towards the drive side by 2.5mm to avoid having the brake disc rub the frame.
The drive side of the SCS compatible hub is no less compatible with bikes running 142mm rear ends as any 142mm hub.
For anyone that’s interested I’ve got a set of carbon 40mm deep wheels for sale on eBay that’ll fit the older Diverge SCS version. This sets particularly niche as it has a 15mm thru-axle dyno hub up front, but they’re 12 speed compatible so will work with all the latest 12spd road groupsets. They’ll also fit 142mm axle rear ends such as the newer Diverge model as I’m supplying a 2.5mm spacer for the brake disk and a 142mm thru-axle. They will need redishing for 142mm which I can do on request.
