Bike creaks/clicks when the crank is under load in the 3 o’clock position. I’ve reproduced the click with the front end off the ground so it’s not anything at the front end. Taken the post out, still clicks, swapped back wheel, still clicks, New bottom bracket, still clicks, different chainset, still clicks, different pedals, still clicks.
Stripped the dropouts off, cleaned and threadlocked, skewer is clean and tight and also got swapped with the back wheel.
I can’t see any cracks on the frame. Anything else to check before I start shopping for a new frame?
