I run an Alfine 8 on my OnOne inbred Fat front rigid frankenbike.
Its great for winter and occasional bike packing.
Iv gone 3 winters without servicing the hub (more of an experiment than laziness)- actually laziness is definitely a factor but for the cost of a new hub Id rather let it wear out…which it shows no sign of doing.
Before I had it on the Inbred I actually ran it on a Commensal Absolute Full susser – that was a mad bike but had a lot of plus points. Certainly the Alfine had no issues smashing through rock gardens!
I run the larger 22T Nexus sprocket combined with a 32 oval chaining. This gives me just enough gears to get up my steep local hills. Iv never found spinning out an issue going downhill – usually concentrating on the trail or having a rest.
The Inbred has slot dropouts which makes chain slack a none issue but no bother running a tensioner.
Tubeless and then don’t even worry about punctures
