Chasing bottom brac...
[Closed] Chasing bottom bracket threads through - easy job?
 benz
Alu frame back from powder coaters with some overspray into bb threads.
Will try Nitromors and gentle brushing, but if this does not work, then should it be a quick, easy and cheap job to do?
Or could I do it myself with a tap or is it a die?!?
Posted : 16/04/2009 10:25 am
If you have one of these, its a simple job!
Remember the B/B has left and right hand threads....
Posted : 16/04/2009 10:34 am
It's a tap. Best to get your LBS to do it, although I have used an old steel cupped bottom bracket (shimano square taper) to do it once.
Posted : 16/04/2009 10:36 am
as above i used an old stainless steel bb to do one the other week and it was fine
Posted : 16/04/2009 10:38 am
Cut some slots in a steel BB cup, and your good to go. Nice and steady does it.
Posted : 16/04/2009 10:40 am
Really nickc? I'd have thought without a taper and a way of aligning the axes (plural of axis) there's be a real risk of cross threading.
Note - I am into my bodging!
Posted : 16/04/2009 11:10 am
1/4 section of an old steel cup & gentle working should do it.
I bought a Rock Lobster from Merlin once & had to send it back due to overspray on the b/b threads. It was bad though, totally un-masked during powdering.
Posted : 16/04/2009 11:14 am
