Brand X dropper lev...
[Closed] Brand X dropper lever problem
10 Users
Offline  FOG
Share this post
I have the older Brand X dropper where the lever has a single bolt holding the lever to the bar clamp. Loosened it off to remove it from bars to add something inboard and now can't get it to work again . Every time I use the lever the whole assembly swivels round the bolt. There doesn't seem anyway to get the lever to lodge on the clamp so it will actuate the cable. Help please! I have disassembled it quite a few times and still can't see how to make it work
Posted : 22/04/2020 8:21 pm
Offline  ta11pau1
Share this post
Is it this one?
If so, don't bother trying to repair, they're junk.
Pretty sure the lever part just has a shaped section that fits onto/into the clamp part to stop it rotating.
edit: this is the newer lever but the old one is the same, the flat on the clamp part fits into the flat section on the lever part.
You've either rounded that bit off, or bolted it up on top of the clamp, so it's not sitting "in" the lever recess.
Posted : 22/04/2020 8:33 pm
Offline  FOG
Share this post
Yep that's the little rascal. I can see more expenditure is called for! Do any of the various other cable dropper remotes fit? Something better than Brand X might be better. Post is fine , remote crap.
Posted : 22/04/2020 9:02 pm
Offline  kneed
Share this post
Can you post up photos of both ends of the lever / bolt: I'm curious as to why its not going back together.
In the meantime- and if you really want to spend money - this is the standard answer to cable lever recommendendations - but takes about 10 days to get to the UK :
https://www.ebay.co.uk/itm/ZTTO-ADJUSTABLE-METAL-MECHANICAL-MTB-SEATPOST-DROPPER-REMOTE-LEVER-SHIFTER-STRIC/133007098951?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Tons of other sellers are available for ZTTO.
Posted : 22/04/2020 9:11 pm
Offline  jkomo
Offline  mulacs
Share this post
Get the ztto one.
Posted : 22/04/2020 9:58 pm
Offline  matt_outandabout
Share this post
Get the ztto one.
+1
For the money, they are ace.
Much better than the original.
Posted : 22/04/2020 10:02 pm
Offline  Poopscoop
Share this post
I have the ZTTO one and the Bonty one.
The Bonty one is *SO* much nicer made than the ZTTO one.
That said, they both work fine. The Bonty one is just nicer.👍
Posted : 22/04/2020 11:29 pm
Offline  RamseyNeil
Share this post
Just put the brand X lever back together the right way and it will be just fine .
Posted : 22/04/2020 11:44 pm
Offline  Poopscoop
Share this post
Oh! Bonty now make an even nicer trigger with I-Spec II and matchmaker compatibility.
Damn you op, in going to "have" to get one now.lol
https://www.cycle-technology.co.uk/shop/products/bontrager-line-elite-dropper-under-bar-lever
null
Posted : 23/04/2020 12:02 am
Offline  dc1988
Share this post
Does the Bonty one run on a bearing
Posted : 23/04/2020 8:35 am
Offline  teethgrinder
Share this post
Don't think so.
Posted : 23/04/2020 12:49 pm
Offline  FOG
Share this post
Finally got the Brand X back together but have ordered a different one. I can't be bothered with the faff every time I need to move controls about
Posted : 23/04/2020 2:12 pm
