These will work fine
https://clee-cycles.co.uk/P1043/product
KCNC Disc Brake Adapter Post Fork – IS Caliper
Disc calliper adapters to mount IS callipers on to post mount forks and frames.
They may not fit all callipers to all forks as there is very little clearance on some designs! If it does not fit – it can be returned.
160-160mm Disc Calliper Adapter – no increase in rotor size – to mount a 160mm IS calliper on a post mount fork with a 160mm disc.
Will also fit a 180mm IS calliper to a post mount fork with a 180mm disc, or a 200mm IS calliper to a post mount fork with a 200mm disc. You do not have to go up a disc size
160-180mm Disc Calliper Adapter – 20mm increase in rotor size – will fit a 160mm IS Calliper to a post fork to run a 180mm rotor – includes black spacers and washers.
160-203mm Disc Calliper Adapter – 43mm increase in rotor size – will fit a 160mm IS Calliper to a post fork to run a 203mm rotor – includes black spacers and washers.
Rear Callipers – the 160-160mm Adapter will mount a 140mm Rear IS Calliper to a 160mm post mount frame with a 160mm rotor – you have to use a 160mm rotor – it is not possible to use a 140mm rotor if the frame is designed for a 160mm post mount.
the 160-160mm Adapter will mount a 160mm Rear IS Calliper to a 160mm post mount frame with a 180mm rotor – you have to use a 180mm rotor – it is not possible to use a 160mm rotor if the frame is designed for a 160mm post mount. [The rear IS mount is designed for a 140mm rotor – this means a 160mm front IS calliper fits a 140mm rotor when mounted on the rear. 160mm rear IS callipers are the same as a 180mm front IS calliper. ]
