I bought an E91 335D earlier in the year and have put nearly 9k on it so far. Bad side, I’ve had a weird issue with brake pad sensors which required the rear pads changed early and all the wear sensors replaced. That’s an issue you could have with any bmw.
I was looking for 330Ds, around the 2008 age and a 1 owner 2006 335D with under 60k popped up privately so snapped it up. It’s auto only on the 335 but I feel it suits it very well. I’ve driven manual 320D’s and felt the gearbox was quite clunky so happy to get an auto. However I find the steering wheel paddles to shift down the auto box (standard on a 335) is useful for faster driving as the front will push wide if you don’t drop a cog for faster corner entry. This is worth considering if you are comparing a manual 330D v auto 330D, depending on how you intend driving it. You can still shift down using the stick on the 330D auto.
The tyres seems to last well, I’ve only worn about 2-3mm out of the rears and it’s been subject to more than a few high speed drifts and aggressive driving. The power is amazing once you are on the move, I’ve been able to out pace seriously fast cars and it makes overtaking a smooth, safe and pleasurable experience on country lanes.
The diesel doesn’t like short trips but we only ever use the car if it’s a journey over 20 miles.
It’s docile when driven normally. I’m sure it’s worse on fuel than the 330D, it gets 35mpg average and 38mpg on a run. Even if abused it still returns 32+. You don’t buy one of these to compare to a 50mpg boring 2l rep mobile. You run these cars because it allows you to have sports car like performance, while driving your bike to riding spots on good roads. Life it short and fuel is as cheap as it’ll ever be right now so do it.
