Hi Soap
Bleeding Hope Tec brakes is little different from bleeding any Hope brakes. I have done lots of cars so bikes are pretty easy….
I have never bled them ‘bottom up’ that seems a strange thing to do – probably involving syringes etc
Get a nice fitting nipple spanner (small ring etc)& a tight fitting length of clear plastic tube. I also have a small glass jar with some older fluid already in it – to avoid air being sucked into the imersed tube.
I adjust the angle of the brake on the handle bar (& pos swivel the steering) so that the resovoir is horizontal. Make sure its always topped up. Use Dot4 or Dot5 but dont mix them. If you are not sure whats in it – use enough fluid to push the old stuff out. I think Hope recommend 4.
Pumping the lever is good as it builds up pressure – then open the bleed valve whilst holding the lever compressed. Lock off the nipple before releasing the lever. You might need to do this several times to get all the air out BUT dont allow the fluid level to drop too low as air will be pushed into the system again.
You are supposed to ‘peel’ the gasket back on – which I try to do but always top the resovoir up to the brim so that the gasket & top displaces the fluid – onto the surrounding rags.
Thats what I do and I am sure others may have some additional tips.
The Tec brakes are extremely adjustable with bite point etc.
You may be doing this already – but hopefully this may help.
