The charity I work for has just bought itself a secondhand HP 2820 laser printer/scanner/copier unit. After a fair bit of fiddling and reconfiguring of firewalls I finally got it scanning and printing over the network.
I then ran into a problem the pages from my Word 2007 document simply wouldn’t print, Word would dump a whole load of data to the print spooler which would then hang about 90% in, until finally giving up after about 5-10 minutes with a “this document failed to print” error; the same document would print quite happily to a newer HP LaserJet 3700.
To cut a long story short, whilst trying to work out what was going on I spotted the .docx extension (indicating a Word 2007 format document) in the document name in the prnter window, and decided to save the document out into 97-2003 format and print agan; guess what, it printed flawlessly (whilst passing roughly two thirds less data to the spooler). I haven’t had time to test whether any Word 2007 document will fail to print (Excel 2007 files seem to print okay) but what’s likely to be going on, a buggy driver (it was released earlier this year, so it up to date) some sort of compatibility issue between Word and the driver/printer or just something dodgy about this particular document? It’s not a huge deal if I can save out to an earlier format and still print but I’m interested as to what might be going on, I’d assumed that Word did the rendering and just told the printer what to print, but this doesn’t seem to be the case.
