+1 for conical bases, they work best in almost all applications. The only exception ime is really skinny/funky shaped rims, I had some BOR (I think) which just didn’t work with anything but their own specific valve. But for everything else, it’s just kinda obvious that a cone fills a round hole best. I do like the valve remover/tightener caps though- cheaply available from ebay/aliexpress if you want ’em
The hiflow ones look interesting but they don’t work with all pumps, which is a way more important part of the job than anything to do with flowing air (considering that practically all tubeless valves have removable cores which do the same job with just a little bonus faff)
It is imo worth paying more if you have tyre inserts though, as with standard valves the insert can block the valve. (I cut out a niche in my insert instead, but the valves with side exits are a nicer fix). But otherwise cheap isn’t just good, it’s better than most.
