I've got a couple of sets of old Shimano brakes that are doing the standard leaky rear caliper thing. I was wondering if anyone had tried the replacement pistons and seals available via evilBay?
http://www.ebay.co.uk/itm/222598568496
Worth a shot or put the 6 quid towards some new brakes?
About time somebody did spares. Please let me know how you get on if you try them.
no, but a disassembly, clean and very careful removal of corrosion from the caliper bores fixed the leak on mine
Interesting. I have not tried but would like to know if they work.
Very tempted, got some in my basket waiting for me to commit!
I just bought some deore calipers and shoved them on, was easy.
Never bothered - just swapped the calipers. Or the whole brakes, more often than not. Good luck though 🙂
What Daern and moonboy said, the callipers are mostly identical anyway.
Wasn't there a thread a while back that attributed the leaks to the o ring on the oil port where the two sides of the calliper join? It might be worth replacing that too.
Theres some awesome chinglish on the e-bay description.
1. contact to make the film using high temperature insulation materials, can rely on heat 300 degrees Celsius, heat and reduce the heat attenuation;
2. Surface four groove air hole design, can reduce the heat transfer contact area, increase the air shuttle, which will help to heat;
3. The back of the depression design, the oil thrust concentrated in the central, so that the piston and the ring concentric activities;
Looking through my spares boxes I have an old caliper that I swapped out for the same leaky reason. I'll probably start by trying to open that up first and see how easy it is to strip down. If I can get at least one complete set of working brakes it'll save me some cash 🙂
I've also got a set of unused LX (old M585s from pre-SLX days) levers and hoses. Are these still OK with more modern Shimano calipers?
The o ring thread I mentioned
http://singletrackworld.com/forum/topic/leaking-shimano-calipers-possible-solution
Thanks for the link Capt.
I think for £2 for 10 of those o-rings and £6 for a set of replacement pistons and seals it's worth a shot at trying to get a set of brakes working as opposed to nearly £250 for a new set of Hopes instead.
If someone does buy this can they let us know if it is in fact "Package included: 1Pcs piston and 1Pcs Sealed" for the £5.99 or 2 pistons and 2 seals a enough to do a full caliper? If it's only one then £12 per caliper is still a cheap fix but a bit more of a commitment for a full bikes worth if it doesn't work!
EDIT: a review from aliexpress shows it to be one piston and one seal, so for a full bike you'll need 4 of these
Any chance for leaking shimano lever spares?
There should be enough spare levers floating around from broken calipers 😉
Yeah,
The o ring sorted my BR785 calipers out.
No noise so far!
Thanks Max
