If you’re changing the gains in the Phantom update software, I’d have to ask why? Just make sure compass calibration is done and you have GPS lockwhen you fly, should be set .. and make sure you’re in the correct right switch orientation if you are flying in NAZA mode.
I’ve not found it necessary to alter the altitude gain, as being too quick makes the flight a bit twitchy when you settle to take a shot.. if you do I think you’d just crank it by 5% at a time till you’re happy?
EDIT: wot rockhopper said. Have a ZenMuse and GoPro 4 on there so it’s about as loaded as a P2 gets and I’ve not had to change owt.
