Hello,
I have a 10 speed Shimano 105 shifter, SL-5700.
I have a Shimano Acera rear mech, RD-M3000, which worked perfectly with it.
Due to fancier parts trickling down from other bikes I am now trying to get a Shimano XT rear mech RD-M780 to work with it and it’s not having it.
The limit screws are fine. With no cable in it sits perfectly in the small cog. If I connect a cable it will change all the way to up to the third biggest sprocket but no further. Pulling on the exposed cable will then get it to shift perfectly into the largest sprocket so that limit screw is fine too.
If I use the cable tension necessary to be able to select the largest sprocket by using the shifter then I cannot get the two smallest sprockets.
Basically, I get either gears 1-8 or gears 3-10 but not 1-10.
Am I missing something here?
Thanks
PS. 10 speed XT cassette 11-34 and XT 10 speed chain if that makes any difference.
