Yet more Mac and mu...
[Closed] Yet more Mac and music related questions
Having successfully ripped my CD's to iTunes (lossless,even managed to get cover art for most) I now want to be able to access them around the house using a Touch & airport express (to a portable stereo via an optical cable). I have tried downloading remote to the iMac (stored in the iTunes folder)but I assume I now need to get it onto the touch - can anyone tell me how to get it working?
The airport unit has an amber flashing light on it, I think it needs to be green to work, again any top tips? (I have loaded the airport disc onto the mac).
Thanks
Nick
Posted : 18/02/2009 2:43 pm
You need to set up the airport express using Airport Utility. Open and follow instructions to set up airtunes.
Then in iTunes you can select the Airport/speakers that you want to broadcast to.
As for Remote, that's an application you need to sync to your iPod Touch.
Posted : 18/02/2009 2:54 pm
I have tried syncing the touch - as I have over 120gigs in iTunes it won't let me. Does this mean that remote won't work for me? The touch is an 8gig version.
Once I am in airport utility it tells me that it can't find any apple wireless devices - the airport express unit is plugged in next to the computer.
Posted : 18/02/2009 3:15 pm
You need to set it to sync manually.
Posted : 18/02/2009 3:21 pm
We've got 3 Airport Expresses and a Time Capsule, and when I was setting them up with the different room names, they didn't always appear in the Airport Utility.
However, if you connect the Airport Express to your iMac with a Cat5 cable then it should appear; then you can follow the simple setup steps, and then disconnect the cable permanently.
The Touch is only a remote - the music is actually streamed from your iMac, and so size doesn't matter.
Posted : 18/02/2009 3:23 pm
The Airport Express is now connected using the cable from the modem. I am now being told 'Problem 1 of 2: internet connection. Your Apple wireless device does not have a valid IP address. Make sure it is connected to your broadband modem or local network, verify your settings & try again....click continue to proceed.'
If I click continue I am then asked if I 'want to continue without resolving the problem'.....but with no indication if it matters.GRRRRRRRR
andym: what is this setting to sync manually of which you speak?
Posted : 18/02/2009 3:42 pm
How are you planning to use the Airport Express?
Do you have a current WiFi network that you are trying to hang off, or will it be standalone?
Posted : 18/02/2009 4:20 pm
I'm probably being a bit thick/naive. We have a wireless router/modem which gets our 'broadband' (0.1Meg) This is attached via an ethernet cable to the iMac (I was getting occasional drop-outs using it wireless). I then need to get data from the iMac to an airport express (at the moment only 1, but potentially more in the future). Does this help?
Nick
Posted : 18/02/2009 10:53 pm
anyone?
Posted : 19/02/2009 5:03 pm
Tell the Airport to connect to the wireless router.
Posted : 19/02/2009 6:07 pm
