XML editor recommen...
[Closed] XML editor recommendations
Preferably open source.
Somethimg that can open a XML file and slow the elements to be edited but without the danger of a txt editor where clumsy people can edit a tag ruining the file.
Posted : 10/05/2018 2:36 pm
i use notepad++, doesn't stop tag editing but its syntax highlighting is good and it will check and highlight errors.
Posted : 10/05/2018 2:41 pm
Was goign to suggest Notepad++ but for the protecting parts of it section, I'd be looking at pairing it with something to do differential stuff to keep a record of what the changes were - or useful answer why are you letting clumsy people near stuff that you don't want changed? Can you not find a better way to expose the bits you want to be editable?
Posted : 10/05/2018 2:43 pm
I want a quick solution for people on site to be able to edit the config files. It more about limiting the potential for errors rather than eliminating. I could write a config tool but thought there must be something like this already in existence... Plus time is a issue.
Posted : 10/05/2018 2:59 pm
Firstobject Foxe can be useful. You can set it to just show the 'tree view', maybe less likely to mes things up than the full text.
http://www.firstobject.com/dn_editor.htm
Posted : 10/05/2018 5:25 pm
Microsoft XML Notepad?
https://www.microsoft.com/en-gb/download/details.aspx?id=7973
Free and XML specific.
Posted : 10/05/2018 6:17 pm
Visual Studio Code is pretty neat
https://code.visualstudio.com/
Posted : 10/05/2018 10:17 pm
Some good ideas. I will now have to fight it to get them downloaded to test.
If not I will have to write something.
Posted : 10/05/2018 10:36 pm
Probably best just to write something then you can sense check what they enter as well.ย  It isn't just a case of messing the tags, they could also enter something that breaks something
...says someone that once put a hole in a block of aluminium by missing off a zeroย  ๐Ÿ™
Posted : 10/05/2018 11:22 pm
