.xls guru help plea...
[Closed] .xls guru help please. Reformatting data
 benz
Need to do some lookups.
Unfortunately some numpties have decided to represent the same data differently.
AB0123
AB123
Any quick and easy way I can delete the zero or indeed introduce the zero?
Thanks
Posted : 21/10/2015 3:13 pm
If it's always the first 2 characters then 3 or 4 numbers you can use something like
LEFT(A1,2)&TEXT(MID(A1,3,99),"0000")
just use 3 0's at the end of the TEXT functon if you want to get rid of the first 0.
Posted : 21/10/2015 3:19 pm
 Crag
if you just want to get rid of the 0 then the easiest way would be to use the find and replace.
Highlight the cells, then Find 0, replace with <blank>
Posted : 21/10/2015 3:24 pm
Although quick and easy you'll also catch any other 10s 20s etc with that.
If you're going to do a hacky find and replace then do something a little more creative like find AB0 and replace with AB.
this of course assumes there's not any ACs BAs etc
Posted : 21/10/2015 3:28 pm
As above it depends if all data matches the format in your examples
If so i'd use 'LEFT' 'RIGHT' and 'CONCATENATE' to pull out the bits I wanted into a new column.
Posted : 21/10/2015 3:40 pm
Depending on the mess its in you could use Text to Columns to separate out the numbers. Then manipulate as required and Concatenate to merge the results.
Posted : 21/10/2015 3:41 pm
if it'll always be 3 numbers i.e. 123 and not 1123, then use this in the adjacent column and copy down the whole list
=IF(LEN(A2=5),LEFT(A2,2)&"0"&RIGHT(A2,3),A2)
this will either copy the adjacent cell if its AB0123 or add in the 0 if its AB123 to give a 6 character result
Posted : 21/10/2015 3:49 pm
