would you absorb it through your skin?
No. But you might absorb some if you're a laydeee...
Nah, but it might cure that embarrassing skin complaint...
Depends how tight your bumhole is
For once I suspect Hora's got a point on this, I would double check my facts but I'm at work and I don't want 'Vodka Enema' on my work computer's search history.
No ones bumhole is 100% sealed when relaxed I bet... 😯
you'd "prune up" quicker as the alcohol would strip your outer dermis of any moisture very quickly. it is sometimes used as a fixing agent instead of formaldehyde because of it's absorbtion rate(2mm in 4 hours)Obviously not vodka as that contains impurities, but industrial alcohol such as methonol or ethanol would be better, but less palatable at around 98% pure
if it did not seal Hora then poo would dribble out or you would inflate every time you went in water
Not sure, but I'd certainly avoid naked flames during my dip anyway!
[i]if it did not seal Hora then poo would dribble out or you would inflate every time you went in water[/i]
Also, is there a control that changes a bottom from blow to suck?
Is it for charity?
Beans for charity, vodka for fun and hijinks
Would the vodka evaporate at a quick enough pace to enable you to get drunk breathing it in?
I had a vodka cocktail bath once.
In fact I lost my cherry in it.
It's ok, I found it behind the sponge shortly afterwards.
igmc.
The Mayans knew how to party (in an admittedly super niche way):For once I suspect Hora's got a point on this, I would double check my facts but I'm at work and I don't want 'Vodka Enema' on my work computer's search history.
[i]A second even more condemning record states, “The men are great sodomites, cowards, and, bored with drinking wine with their mouths, lie down and extending their legs, have the wine poured into their anus through a tube until the body is full” (Anonymous Conqueror,quoted in Anawalt 1993:27).
The characteristics of alcoholic enema use thus appear to have continued uninterrupted from the Classic period Maya through to the conquest-era Huastecs, though such rituals were never adopted by the Aztecs[/i]
http://www.academia.edu/3811531/Blood_Water_Vomit_and_Wine_Pulque_in_Maya_and_Aztec_Belief
On a more practical level, a brandy glass floats: thus one can lie in a hot bath with a glass of one's favourite single malt* which is warmed to blood heat and slides down a treat. It is absorbed rapidly, and the bathroom smells like a distillery.
*Armagnac also works, other fine spirits are available.
I suppose you could replace the brandy glass with a length of garden hose and a funnel. Might need to tie it to a rubber duck to keep it afloat.
Cant you inject spirits for a quicker "hit" probably more efficient than absorption.
Shots in the eyeball are popular among younger idiots, I understand.
We need to link this thread to the Christmas party thread really
Opening this up a little more, can you absorb water through your skin? It might explain why every time I go swimming I need to wee more than I would otherwise (non swimming).
vapourise it and breath it in. the surface area of lungs would mean a very quick effect.
[i]can you absorb water through your skin?[/i]
yep, it's why you 'pucker up' when in it too long.
It depends on the level of salt in your skin v the surrounding water as to how much this happens but your skin is permeable to water and blood will carry excess away and through your kidneys.
You will sweat less in water which would increase the amount of liquid in your bladder over time too.
If you are doing the crawl, then your todger is lower in the water than your bumhole, so the pressure differential means you start taking on water.
Or you have forgotten to take out the funnel after having a bath.
I'd get drunk if I sat in a bath full of vodka, it'd be rude not to.
Might not absorb through skin, but by taking a straw as backup, I'd get a skinful.
I'd imagine if you were sitting in a bath of vodka you'd be drunk but correlation and causation aren't the same thing.
can you absorb water through your skin?yep, it's why you 'pucker up' when in it too long.
Not sure this is true. Wasn't there an experiment recently that proved the puckering up was an autonomous nervous system response?
http://www.theguardian.com/science/2013/jan/09/skin-wrinkle-water-grip
It is popularly believed that fingertips absorb water and swell, making the skin ripple with tiny folds. But this was ruled out by studies that showed the effect disappeared when nerves in the fingers were damaged.
