Worn hex screw
Worn hex screw
My 2.5 hex screw is worn insofar as I cannot turn it, even after lashings of WD-40. Anyone know what tool or method I can use to turn it? It's the hinge on an outside french door.
Thanks.
Posted : 28/09/2022 11:41 am
I've got some lifeline pro hex keys that have a part for removing rounded hex.
Halford have a kit that might help?
That or an impact driver might work?
Posted : 28/09/2022 11:45 am
Is there room to use screw removal/extraction/gripping pliers on the head?
Posted : 28/09/2022 11:52 am
Perfect thanks.
Posted : 28/09/2022 12:06 pm
 kilo
If all else fails. Cut a slot in it with a dremel use a big screwdriver. Or move house.
Posted : 28/09/2022 12:19 pm
Isn't the standard answer to try & find the nearest Torx driver & bash it in? It should give you more purchase than the worn hex.
Posted : 28/09/2022 1:46 pm
Ive had some success drilling screws out, then gluing a dowel in for a replacement screw to bite into.
Probably a way down the list of options to try.
The other ootion I have is damaged screw extractor bit, basically bits that drill in the wrong direction, they usually bite after a while and oit come the screw. Pretty sure the smallest bit I have is for 2mm screws.
Posted : 28/09/2022 2:03 pm
Cut the end off the worn allen key. Now new and unworn ๐Ÿ™‚
Posted : 28/09/2022 2:08 pm
I decided to move house, country's going down the drain anyway.
Posted : 28/09/2022 3:42 pm
Hammer in a torx bit to the offending faster then undo. Worked for me on a thru-axle.
Posted : 28/09/2022 4:27 pm
