Getting quotes for a floor installation.
For fitting engineered boards as a floating floor is working out at about £65 per sq metre.
Is this typical? Seems a bit high to me.
Does sound a bit steep, sorted out my friend's floor for £50ish per sq metre for 36m^2 room. Engineered boards were £30ish per sq metre and labour was around £600 for 3 guys to lay the floor, fix the skirting and a do a couple of other small jobs.
Used [url= http://www.ukflooringdirect.co.uk/ ]http://www.ukflooringdirect.co.uk/[/url] for the boards
I'd expect £10 - 20 a square metre to fit it., depending on area / awkwardness.
I can, pretty easily, do a typical bedroom, (what, 20 sq m?) in a day, including new skirting boards. My usual day rate will be £150, but usually less than that for floors as there is little skill involved compared to other stuff I do.
I wish!!! I shudder at the bill for the hand laying and restoring of the reclaimed parquet my wife has chosen.
But for normal stuff, seems steep.
I think some of the expense is that it's a hallway in bungalow and has 6 doorways, makes things a bit more complicated.
alanl - where are you? I'm guessing your not near me in the SE?
[tannoy] calling deadly darcey to the forum [tannoy]
Where the hell is he at the minute? Can't be busy surely?
Did that including varnishing/oiling?
I oiled myself before it was layed. I got 40sqm done in just less than a week by my builder £150/day - 5 days in total - so £18/sqm. 3 rooms - bit fiddly in places i.e. we wanted it to go under our breakfast bar and cabinets. And he did an amazing job around the fire place.
Skirting was done separately.
[i]I oiled myself before it was layed[/i]
you might want to rephrase that 😉
Make sure you're sitting down when they give you the quote..
Especially if it's not been cleaned off before you buy it,
I did it myself when my mrs got some off eBay,, it still had bitumen on the back and was a pita to clean, it looks lovely now it's down and should last longer than me, but never again...
Laid and sanded
[IMG]
[/IMG]Varnished
[IMG]
[/IMG]DeadlyDarcy's the man on here for floor advice..
wrightyson - Member
Don't interrupt him, he wants to go home tomorrow....
Fwiw I got mine from here http://www.factory-direct-flooring.co.uk/abbey-calder-oak-21mm-brushed-oiled-plywood-core-engineered-flooring.html some good sale prices.
I've got 5m2 of that ^^ sealed and boxed spare at a good price if anyone's needing a small project
