Wireless router rec...
[Closed] Wireless router recommendations?
 gamo
Looking for a new router for the house, so whats good and reasonably
priced for basic wireless internet connection?
Replacing a six year old Belkin G which is now decidedly shonky!
Cheers G.
Posted : 28/01/2011 4:04 pm
I'm happy with my Linksys WAG160N.
Posted : 28/01/2011 4:07 pm
Netgear DGN1000 would be my recommendation!
Posted : 28/01/2011 4:20 pm
I also have a Linksys/Cisco WAG160N, which has a 300Mbs speed, was incredibly easy to set up and has a handy network map and connection repair feature.
I have 10 pieces of equipment that run via the router in some description or another. It does drop out occassionally, but I'm usually re-connected in seconds, rather than the 5+ minutes it used to take my old Thomson router supplied by Tiscali.
Linksys, Belkin or Netgear are all good. Was your G rouer ok, or do you need to extend your range?
If you dont just go for a G router, although you can get Netgear DGN1000 from about £35 if you look around.
Posted : 28/01/2011 4:21 pm
 gamo
Range on the G was fine covered the house garden etc. It just drops constantly and takes an age to reconnect(if at all!).
I have an Amazon voucher kicking about so will check out any recommedations there.
Posted : 28/01/2011 4:26 pm
 gamo
Quick check says the Linskys not compatable with talk talk?
Posted : 28/01/2011 4:30 pm
Strange that gamo, as I'm sat here using Talk Talk (was previously Tiscali, but they got bought out/changed name, whatever). Unless it's something to do with still being on the original Tiscali server and there's a different one for original Talk Talk users????
Posted : 28/01/2011 4:39 pm
I would keep away from Belkin personally, I have had nothing but trouble.
Linksys/Cisco is always my first choice.
Posted : 28/01/2011 4:42 pm
Beware Netgear N routers (check models carefully)
We had a DGN2000 and the ethernet ports packed up. Apparently this is a common fault, linked to the design being prone to overheating
Currently trying a Billion, but too early to tell. Easy set up and good signal strength, just hope it lasts longer than the Netgear.
Posted : 28/01/2011 4:43 pm
Linksys, Netgear... to be honest, most home Internet routers are much of a muchness these days, so long as you stick to a known brand and avoid the bottom-feeders you shouldn't go far wrong.
Posted : 28/01/2011 4:45 pm
 anjs
draytek 2820 but might be a bit over the top for your requirements
Posted : 28/01/2011 4:49 pm
I've got a Billion 7300n,which replaced a Belkin that dropped out and needed rebooting,or resetting at least once a day,the Billion runs a lot cooler and after 3 months has been much more reliable,with better signal strength.
Ian
Posted : 28/01/2011 4:55 pm
anjs - Member
For most small offices they are OTT.
Hmm i've heard a few of reports of DGN2000's dying.
Posted : 28/01/2011 5:01 pm
If your wireless was working fine and has now gone shoddy, a neighbour may be running on the same channel as your WiFi.
Download [url= http://www.netstumbler.com/downloads/ ]Netstumbler[/url] and run it on your laptop to see what channels neighbours are running and change channel accordingly.
Posted : 28/01/2011 5:07 pm
Had an unbreakable Dlink (506T I think) for about 4 years until last summer. Replaced it with a Netgear DG834G and it's been a POS the last few weeks; connection (wireless and wired) drops virtually every day and has to be rebooted multiple times.
Not impressed - which is contrary to 95% of reviews you'll find.
<goes off in search of guarantee>
Posted : 28/01/2011 5:11 pm
I got one of [url= http://www.expertreviews.co.uk/wireless-routers/279061/tp-link-td-w8950nd ]these[/url] from Amazon - £25 and working flawlessly so far.
Posted : 28/01/2011 6:34 pm
I found that if the DGN1000/2000's have a problem with the ethernet ports they can be set to fixed Ip's. Could be a design floor but Netgear's customer service is great so will always go with them.
Posted : 28/01/2011 7:29 pm
