Wireless Audio Send...
[Closed] Wireless Audio Senders
anyone ever used one to run sound from a tv through a stereo?
Any good? Recommendations?
Posted : 01/12/2010 5:41 pm
we tried one to send the TV signal (i.e. satellite) to a TV in the conservatory. Never really worked that well, but it all became academic when the telly in the conservatory first died & then got burgled
how close together are the TV & stereo? If your TV has phono outputs & the stereo has spare phono inputs, provided they're not too far apart, you could cobble up some long phono leads. Might look a bit messy though
But if you have a fairly modern TV with Optical audio out & a surround sound home cinema system with Optical audio in, that might be a better bet
Posted : 01/12/2010 6:01 pm
The trouble is that my tv is on the opposite side of the room to my stereo and any cables would have to be taken over a doorway, otherwise I would connect it with a standard cable.
Same with surround sound: to get the full effect I'd have to have cables all over the room.
I was just after some simple stereo speakers that are better than the on-board ones (Panasonic LCD, less than a year old), that I can plug straight into the tv and put on the stand either side of the tv, but I then saw a wireless sender unit and wondered whether that would work.
Posted : 01/12/2010 6:09 pm
if it's in the same room it should be ok, but don't take my word for it.
If the room is carpeted, if you had a surround sound system, you could run the speaker cables under the underlay
Posted : 01/12/2010 6:34 pm
