Windows update has ...
[Closed] Windows update has borked my PC
Running windows 8.1, installed a bunch of updates last night and now it won't boot normally and keeps going into safe mode.
Have tried repairing, nope.
Have tried system restore, not so far. Initially tried one from yesterday, no joy, currently restoring to one from last week.
Anyone got any pointers please?
(No mention of MACs please, as one button mice are just wrong!)
Posted : 10/07/2014 8:10 am
my MAC mouse has two buttons.
Posted : 10/07/2014 8:13 am
Good for you. ๐Ÿ™„
Any help with the actual problem?
Posted : 10/07/2014 8:17 am
System restore would've been my first suggestion but it looks like you've tried that.
If it boots in safe mode, another option is to try and remove the updates through add/remove programs. Once the screen's opened you should be able to display updates and identify from the date when they were installed. It's a faff but might work?
Posted : 10/07/2014 8:21 am
Chkdsk would be my first port of call there.
Posted : 10/07/2014 8:44 am
Thanks Cougar, to find and fix any disc errors?
Posted : 10/07/2014 8:47 am
Anyone else help?
Posted : 10/07/2014 11:33 am
my first port of call would be system restore from at least a week ago (which is what you are trying now)
Next i would go into update history to see if any are failing
Finally I would go with singletrackstinker's suggestion and remove the updates through add/remove programs. However if system restore worked i'm not sure you should see anything here
edit: oh of course and Cougar's suggestion of a disk check as if you have a failing disk everything gets borked. Some PCs also have utilities that do a complete hardware check including memory. I would also be doing the memory check as system restore usually fixes things
Posted : 10/07/2014 11:49 am
Do you get an option to 'Boot Normally'? Have you tried that?
Posted : 10/07/2014 12:31 pm
Stand down, Im officially a dunce.
I'd forgotten that I'd been running an AV scan in safe mode recently. So when the PC boots up it goes straight into safe mode. Thus stopping the updates installing properly.
It was late last night and I was tired, I'd forgotten to turn off boot into safe mode. ๐Ÿ˜ณ
Early night for me tonight.
Thanks for all those who helped, you may now mock me.
Posted : 10/07/2014 3:04 pm
(I thought about helping but couldn't)
Posted : 10/07/2014 3:06 pm
Posted : 10/07/2014 3:07 pm
