Windowtrackworld up...
[Closed] Windowtrackworld upvc content
Fitting upvc windows, how difficult can it be? Looking at chopping out a large picture window and replacing with 2 smaller ones. I know I need a buildings inspector to check out the work and the glass/energy spec/vents need to comply, i'm reasonably competent having renovated a house previously.
Is there some sort of magic involved or is it just straightforward? Any tips/things to watch out for?
Posted : 05/01/2018 7:41 am
Its a pretty simple job for a DIYer. Only issue is they can be heavy so you may need two people. Can't think of any pitfalls other than getting the right size.
Posted : 05/01/2018 7:59 am
It’s very easy and you can do a much better job than a professional doing it in a rush.
The biggest thing to check for is if you have a lintel that supports all the brickwork above. Don’t assume there is one already.
I just blocked up the bottom of a patio door and installed a window and cut out below a window and installed a bifold door. I had a concrete lintel on the inner skin of brickwork but nothing supporting the outer skin. It would of originally been built on a structural timber frame. I had to prop the wall, cut bricks out at the sides, cut the mortar out the cavity and install a big steel angle. It was hard work but not complicated.
Posted : 05/01/2018 8:27 am
