Will it chop? (Axe ...
[Closed] Will it chop? (Axe question)
 spw3
Chaps,
I have bought a bag of logs from B&Q for a fire this weekend but all the kindling I have has been scavenged from the woods and is still green and damp. Will a hand axe suffice to chop one of the logs (12" logs, already halved or quartered? A splitting maul sounds way more hairy chested but feels like overkill.
Cheers!
Posted : 06/01/2016 9:34 pm
Yup, it will.
Yes. Hand axe is fine.
Take care...
Youtube Ray Meares chopping wood for guidance.
Posted : 06/01/2016 9:35 pm
 spw3
Awesome. Any ideas on where I can get one by Friday night?
Although I'm wary of "buying cheap, buying twice" so worry about the obvious answer of going straight back to B&Q etc
Posted : 06/01/2016 9:36 pm
Yup-Screwfix
Posted : 06/01/2016 9:37 pm
B&q used to do fiskars which are good enough
Posted : 06/01/2016 9:38 pm
Go to a local green grocer and blag / get a few wooden crates?
The firewood from B&Q should be dead dry so won't need much kindling if any if you use a fire lighter.
Posted : 06/01/2016 9:39 pm
Buy a bag of kindling as a cheaper option? Unless you need the axe anyway
Posted : 06/01/2016 9:44 pm
 spw3
<Heads off to google Screwfix and Fiskars axes>
Posted : 06/01/2016 9:45 pm
Or go back to the woods and pick up some [i]dry[/i] twigs
Posted : 06/01/2016 9:50 pm
Buy a splitting maul head, and mount it in a block of wood (cut a square hole through, or just use two solid bits clamped on each side) with the blade uppermost. Place your soon-to-be-kindling wood on it and hit the top with a lump hammer.
Much more control than using an axe, and once you get to the skinny bits it feels much nicer than swinging an axe towards your fingers...
A DIY version of this:
Posted : 06/01/2016 9:57 pm
 spw3
I don't need an axe but I really want one.
As for picking up dry twigs in the woods, have you looked out of the window lately?
Posted : 06/01/2016 9:58 pm
Try your local hardware shop or garden centre.
Posted : 06/01/2016 10:04 pm
I pick my kindling from the woods and they were under 4ft of water the other day, get stuff thats caught up off the ground.
But you [i]do[/i] need an axe cos every home should have one, in my view these are a good balance, small enough for kindling, big enough to cut down a tree if you [i]really[/i] need to, nice quality without the premium cost of a gransfors. And theres a lot to be said for a wooden handle.
[url= http://www.heinnie.com/hultafors-agdor-large-trekking-axe ]link[/url]
Edit: they are out of stock but you can get them in a few places, try ronnie sunshines
Posted : 06/01/2016 10:23 pm
Husqvarna axes are really good and fiskars got one of each,small hatchet for kindling and 700mm splitting axe for logs, their actually made in the same factory .
Posted : 06/01/2016 10:53 pm
I have a B&Q hatchet. I've got sharper butter knives. Had to do some serious filing to get any sort of edge on it.
Now have a GB small forest axe. More like the proverbial hot knife through butter....
Posted : 07/01/2016 9:44 am
I try not to chop logs for kindling, there's too much stuff lying around that can be used instead, save the logs for burning whole. If you live near the beach, a couple of big blue ikea bags can be filled in mutes with all the wee stuff that gets washed up and only takes a very minimal time if any at all to dry.
Small twigs from the woods kept in a basket at the fire dry out very quickly too.
Posted : 07/01/2016 10:10 am
