Why is my house so ...
[Closed] Why is my house so cold?
51 Users
 hora
100% double-glazed
30c combi-boiler with all recent radiators
No drafts
Front (double-entrance/porch) has a draft seal all round and double-glazed.
Rear room, hallway, stairs and landing are wooden-floored but no gaps.
The living room- v.thick underlay and thick carpet yet its the coldest room.
The loft is insulated (checked)
The walls are pre 1930 brick and we've been told cavity wall insulation isn't possible.
Warm if you keep heating on however literally as soon as it goes off the house is freezing which says to me the house is very inefficient and shouldn't lose heat that quickly. Really scratching my head here.
Anything I can do?!!!
Posted : 04/12/2011 5:14 pm
Run the heating for longer so as to warm the actual structure inside the house. There are many tons of interior walls, fittings and furniture and it takes several days for all of this mass to warm up. If you keep turning off the heating you don't give it a chance.
Posted : 04/12/2011 5:17 pm
Time to get your thermals out hora
*wolf whistles at hora*
Posted : 04/12/2011 5:18 pm
Also is it at all damp? Humid air feels colder than equally cold dry air.
Posted : 04/12/2011 5:22 pm
Use heavy curtains and make sure you close them all when it.s dark
Posted : 04/12/2011 5:26 pm
Haunted.
how deep? needs to be 300mm ish
100% double-glazed
thick curtains with thermal lining help
put a foil reflector on the wall behind the radiator
Posted : 04/12/2011 5:27 pm
No draughts = no ventilation = damp? Get a dehumidifier?
 hora
Lowey. We've got a farmyard figurine toy kit that is almost impossible to fit back into its plastic case and close.
Earlier this week it was neatly packed away. Very neatly and mrshora asked me 3 times if I did it. No.
Posted : 04/12/2011 5:30 pm
my house is cold too, but thats because we just had the fireplace tiled.
Tiler didnt tell us we wouldnt be able to have the fire on for 3 weeks!!!, if I had known that I would have waited until bloody spring!!!!
Me the Mrs and cats are missing the fire!!!! brrrrrrrr!!!
Posted : 04/12/2011 5:33 pm
I see what you mean, but draughts and ventilation are two very different things really.
A draught is not controllable and makes your house very cold.
Ventilation is controllable and won't (unless you want it to)
Posted : 04/12/2011 5:34 pm
 hora
Dehumidifer? Might give it a whirl and hire one from HSS.
Dehumidifiers are great - you'll be amazed at how much water they pull out!
You may as well buy one as you'll get a good one for around £100
It's also great for drying out your freshly washed clothes - speeds up the process.
Oh! and...
DON'T! The cavity is there for a reason. Leave it be.
Posted : 04/12/2011 5:49 pm
I'd say you just need to keep heating the fabric of the house, and just accept the heating bills. I dont run my heating during the day, and on friday night the house wouldn't warm up
With single leaf wall construction I think your only option for significant improvements are to dry line the internal walls with thermal plastboard, or build a cavity, i.e a second wall, seen it done, but I do wonder what the payback would be!
Posted : 04/12/2011 5:54 pm
 hora
"It's also great for drying out your freshly washed clothes - speeds up the process"
Damp clothes/hard for them to dry indoors at the mo'. Hmmm I'll have a look at argos/amazon etc
Posted : 04/12/2011 5:55 pm
Why shouldnt Hora's cavity be filled....?
( I dont usually like double entendre's but I do like to slip one in every now and again... )
Posted : 04/12/2011 5:56 pm
Pre 1930s and there's unlikely to be a proper cavity to fill
Posted : 04/12/2011 6:00 pm
Oh do you now! 😉
Posted : 04/12/2011 6:01 pm
Put a jumper on you northern ponce 🙂
Posted : 04/12/2011 6:02 pm
Pathetic, speak to any expert. You need insulation.
Why is it not possible?
Age of the double glazing? Old stuff is thin compared to modern units.
Ditto to the loft insulation, wants to be 300mm. If it's less get more and go 90 deg i.e. across the joists
Dry lining could be an answer
Here's the one we got Hora
[url= http://www.amazon.co.uk/Delonghi-148110002-DeLonghi-Compact-Dehumidifier/dp/B000BP81DW ]Amazon link[/url]
I can highly reccomend it, great little unit. Have a look about as I'm sure we paid just under £100 a couple of years ago.
Honestly, you'll be shocked at how much water it pulls!
EDIT:
[url= http://www.ebay.co.uk/itm/Delonghi-DEM-10-Dehumidifier-NEW-Box-/120821725287?pt=UK_Home_Garden_Hearing_Cooling_Air&hash=item1c21893867 ]on Ebay for £105 posted[/url]
Posted : 04/12/2011 6:03 pm
lol my house is the same !!!! its a victorian terrace and quite big....ech room has high ceilings... so its freezing in winter and warm in summer....lol..
as i type now in the back room my right hand feels like its died...ruddy frostbite i tell ya..
Posted : 04/12/2011 6:06 pm
How much are you willing to spend on improvements?
Posted : 04/12/2011 6:08 pm
Keep doors shut upstairs to prevent heat moving to the top of the house.
Tuck curtains behind the radiators to direct heat into the room, rather than into the window.
Got an unused fireplace? I can feel a draft going up mine, you can get a chimney balloon that blocks the chimney, it has a couple of gaps to ensure it remains ventilated and will melt if you light a fire/turn on the gas fire. I just have an empty hearth so I don't have the worry of keeping a gas appliance ventilated so am planning to use the cheap method, apparently you can use the foil inner from a wine box and inflate it in the chimney, with a bit of plastic pipe tucked in the corner to keep some airflow. (the proper thing costs about £25!)
Posted : 04/12/2011 6:14 pm
My landlord gave us a dehumidifier when I complained about the fact there was enough condensation on my walls that it was running down and getting my stuff wet!
Not only do I now have drier stuff, no more mould and un-infected sinuses I have a much warmer room - although you have to run it regularly so might add on to your bills a bit (I have no idea how much it costs to run - we just accept a big bill cos with 5 students we use lots of power!).
Definitely helps for clothes drying too!
Posted : 04/12/2011 6:20 pm
Hora, get in touch with teh Energy Saving Trust.. they have loads of grants and stuff...
www.energysavingtrust.org.uk
Really helpful
Posted : 04/12/2011 6:27 pm
perhaps - like my house - there isn't a cavity just a 9" solid wall?
Posted : 04/12/2011 6:33 pm
Maybe its because your in the Cardboard Box outside the house your describing
Posted : 04/12/2011 6:35 pm
For flips sake people: The outside temperature's just dropped by 15deg, there is not much heat being stored in the brick your house is built of simply because up untill now it wasn't necessary to heat much to warm the house up.
If you wan't your cavity filled I can highly recommend Leith Docks for this..might be a bit far just for one evening though..
Posted : 04/12/2011 6:40 pm
try heating on a lower setting but on for longer?
Posted : 04/12/2011 6:44 pm
 hora
Chickenman true
Grantway eh??
chickenman - Member
[So Hora is lodging in the Wheelie Bin !]
Posted : 04/12/2011 6:46 pm
 hora
My box is bigger than yours grantway.....and its branded
Posted : 04/12/2011 6:53 pm
The walls and floors. At best a standard 30s wall is R = 0.5 The floor if it's 25mm boards over a ventilated air space will be around R= 0.3.
If you have 200mm of rock wool or fibreglass in the roof that will be around R = 5 to give you a comparison.
Insulate the walls on the inside or outside depending on space restrictions and budget, 100mm of polystyrene, wood fibre or polyester will bring your wall up to R = 3+. Put 100mm of polyester between the floor joints for R = 3.
Posted : 04/12/2011 6:54 pm
Hora, are you in Greater Manchester? Try [url] http://www.getmetoasty.com/ [/url]
I had a head full of broken biscuits when we were being briefed but all the Greater Manchester council staff were hauled in to be told about it, promote it at every opportunity blah,blah
I seem to remember you get a free survey, cavity wall if needed is free and loft insulation if needed is a maximum charge of £60.
I think AGMA (Association of Greater Manchester Authorities) underwrite it but get 10% more than the cost back fron central govt.
[img] http://www.smileys4me.com/getsmiley.php?show=1788 [/img]
+ what chickenman said, but nothing is really going to have a positive effect as long as the garden is being heated up.
This worth a look [url= http://action21.co.uk/existing_buildings.html ]http://action21.co.uk/[/url] as well as the EST stuff.
Posted : 04/12/2011 6:56 pm
Is it a solid concrete floor or wooden with joists underneath? Could be a void that is sucking the heat too.
Don't jump to it being condensation. You usually see signs of that like damp patches, condensation on frames / windows in the morning etc
Posted : 04/12/2011 7:04 pm
 hora
We do get a fair bit of condensation on all upstairs windows (especially) in a morning. Why upstairs? Its abit of a worry when you hear hora jnr coughing like a smoker so I think a dehumidifer is essential.
It is a void under the floor with vents built into the outside walls.
Looking at it, I 'think' its lime? Looks like it at the base of the underfloor void.
Monksie will do. Thank you.
Internal wall lining? Recently decorated so want to avoid
Posted : 04/12/2011 7:12 pm
Second foil behind radiators.. ESP if on an external wall. Radiators under windows used to be the done thing but think it just leaks heat? Think you can get interior insulating platerboard or panels that go onto exterior of property adding a good 50mm of insulation.. All the housing associations are doing it up here to the council houses..
We do get a fair bit of condensation on all upstairs windows in a morning. Why upstairs?
Heat rises.
Plus I'm guessing your bedrooms are upstairs? The human body produces a lot of H2O as a byproduct of breating.
Posted : 04/12/2011 7:19 pm
Do you have small vents built in to the frame of the windows? These need to be open to allow some air flow and prevent condensation. A dehumidifier is no substitute for proper ventilation.
The void under the floorboards is sucking heat. It is a crap job but suggest insulation under there as Edukator mentioned. Very similar to a case study I looked at the other month. You need to lift the floorboards - sorry.
Posted : 04/12/2011 7:25 pm
Or dig access from the outside or from a trap you make in the floor.
Posted : 04/12/2011 7:30 pm
 hora
Tootall - How about a plastic undersheet that sits ontop of the floorbboards similar to pond-liner? (If such a product exists)
I don't like bare floorboards anyway and was thinking of a jute or coir weave carpet in the hallway/stairs/landing and backroom
I live in a Victorian terrace. I notice that the front room is a lot colder than the rear. The front is a wooden floor and the rear is concrete. I was advised by an architect to put some insulation in the cellar under the wooden floor. Didn't bother but probably not expensive. (I have some plasterboard type stuff as a ceiling in cellar so insulation could go in here).
[Hijack]BTW house is for sale if anyone interested in something near Derby city centre and nice park [/Hijack]
Posted : 04/12/2011 7:36 pm
With the best of the multi-layer insulators (layers of aluminium, polythene and polyester) you can get R = 2.3 for only 30mm. It's impermeable though. My favourite insulator at the moment in potentially damp situations is recycled polyester. I've got the thicker R = 3.05 version of [url= http://www.castorama.fr/store/Isolant-fibre-polyester-80mm-prod5850002.html?navAction=push&navCount=6 ]this polyester[/url] under my floor boards.
Posted : 04/12/2011 7:41 pm
The link I put previously to action 21 shows one way, I've also heard of people using loft insulation held up with chicken wire, but would also work if you have a plasterboard ceiling.
I did the under floorboards insulation in our dining room. It has made a fair it of difference. Took up a hatch of maybe three widths of floorboard and went down into the crawlspace (18-36") Used Space Blanket jammed between joists and stapled in place. Messy job, but I was redecorating and putting a new carpet in too. Put a higher TOG rated underlay in too, and I think that made more difference, along with completely sealing all gaps under skirting.
[url= http://www.carpet-underlay-shop.co.uk/cloud-9-cumulus-pu-carpet-underlay-11mm-19-p.asp ]http://www.carpet-underlay-shop.co.uk/cloud-9-cumulus-pu-carpet-underlay-11mm-19-p.asp[/url]
Makes even thin carpets feel lush too.
Posted : 04/12/2011 7:46 pm
Why is your house cold?
Because UK building standards and thermal performance standards are useless, on new houses and even worse on old houses.
Where to start? Buy the [url= http://www.amazon.co.uk/dp/1898130051/?tag=sustainable0f-21 ]Green building bible[/url] and join the [url= http://www.aecb.net/ ]AECB[/url]
Posted : 04/12/2011 7:53 pm
Hora - don't put a platic sheet down on the floor.
Whilst you may think your current floor is tight and sealed there will be air getting through - this is a good thing as it provides ventilation. Which you need.
Can you tell I'm a civil engineer?...
Posted : 04/12/2011 8:03 pm
All rads bled?
Posted : 04/12/2011 8:08 pm
Plastic isn't a substitute for proper insulation. You need a bit of thickness under there. That is your major leaching of heat under the floor.
Find someone with an infra red digital thermometer (or spend £20 on EBay on one). Then go around the house checking the temperatures of the walls / windows / floors etc and you'll see for yourself where the heat is going.
Posted : 04/12/2011 8:42 pm
We normally insulate suspended wooden floors with 200mm of Mineral wool (held in place with stapled 3mm ply straps)
If there is enough space, it's done from underneath. When done that way we would seal all the edges with expanding foam and cracks with frame sealant.
If we do it from above, we would remove all the boards, fill with the same insulation held in place with a wire mesh, and then replace the floor with 22mm t&g chipboard (glued and screwed) with a foam underlay underneath.
Then seal all the edges to make it air tight.
The idea that you use gaps in between tongue and groove flooring and spaces round the edge of badly fitted floors as "ventilation" is frankly rediculous.
You need to be able to control ventilation, gaps are just draughts that you can't control, and they are not recommended.
Posted : 04/12/2011 8:56 pm
Having a purge here - first Winter in new house. Extra insulation added to loft plus draught excluders on all the downstairs doors.
Downstairs bathroom is like an ice box and the ceramic tiles don't help.
Next job is sorting out reasonably heavy duty curtains as the old double-glazing is draughty.
Am determined to reduce heating costs!
Posted : 04/12/2011 8:58 pm
The downstairs of my house is feezing since i took out the wall between the living room and conservatory, brrrr.
It does look nice though 🙂
Posted : 04/12/2011 9:12 pm
I'm sure all those numbers on your heating bill will be just as lovely! 😀
Posted : 04/12/2011 9:16 pm
I must admit the heating is on higher than usual and it doesn't take the chill off the living room, and it's not even that cold or frosty yet 😕
I have a nice big blanket though
Posted : 04/12/2011 9:20 pm
While on the subject, does window insulate film make much difference? I've got a big single glazed window in my kitchen. There is no radiator in there, two external walls and roof (which i suspect has little insulation). There's no chance of getting a new window as I rent.
Posted : 04/12/2011 9:28 pm
I really have no idea why that could be... [img] http://www.smileys4me.com/getsmiley.php?show=2140 [/img]
@CaptJon, I don't know about this film of which you speak but have you thought about secondary glazing? No idea on cost or availability or quality or look or....
Posted : 04/12/2011 9:33 pm
After a winter last year spent with the heating on full blast and the house always feeling cold it's a pleasant surprise to find that our new (to us) house doesn't seem to need heating. It's 4 degrees outside and we've not needed the heating on all day and I'm normally a bit nesh.
Not really a huge difference between the two houses, both had cavity fill and 300mm loft insulation, similar ages, both semis so the difference in warmth is a bit of a mystery.
Posted : 04/12/2011 9:36 pm
Plastic film is OK, easy to fit and very cheap.
Slightly better option is a plastic sheet cut to size and attached magnetically (or with other frames)
http://www.theonestopplasticsshop.co.uk/clear-cast-acrylic-1000-3-mm-p-1395.html?osCsid=e5t7emnvqah27polrtregfgst5
Good tips on insulating under a suspended floor, we've got high ceiling cellars so I need to get on and do that.
Posted : 04/12/2011 9:37 pm
As stated - unisulated suspended timber floor.
Posted : 04/12/2011 9:42 pm
 hora
"both semis so the difference in warmth is a bit of a mystery."
Next door is identical to ours. Not as good on the combi etc but a big difference on warmth when neither is heated. Maybe previous owner had the underfloor mod etc.
Posted : 04/12/2011 9:58 pm
Orientation?
Posted : 04/12/2011 10:05 pm
Orientation +1. Probably has a nice south facing wall and heat soaked brickwork.
Thermal insulation is to reduce heat loss but also prevents heat gain, like a thermos flask.
Posted : 04/12/2011 10:27 pm
gravity-slave,
Pay particular attention to the edges of each room, expanding foam round all the edges to seal the gaps.
We put lights on in the room above and keep cellar dark to spot any gaps in the middle of the floors too. But obviously that won't work if you have carpets. Just put frame sealant anywhere that looks like it might provide an airway.
And put a plastic membrane between the insulation and any outside Walls, just in case of damp (we use the bags the insulation comes in normally)
Posted : 04/12/2011 10:34 pm
Try this web site justinsulation.com
[url= http://www.just-insulation.com/celotex_pl4000_pir_insulated_plasterboard.html ]justinsulation.com[/url]
Also have you had your heating system power flushed
if not give that a go, and also are your radiators full of rust
if so change them ASAP
Posted : 05/12/2011 5:28 am
Our front room was always cold so i replaced it with a double radiator
Posted : 05/12/2011 5:45 am
Have you considered heat distribution? In our house there's a bit of interplay between the thermostat and the TRVs. The thermostat is on the ground floor at the end of the circuit, so if you turn it up the TRVs on the other floors can close and direct more heat to the ground floor which heats that floor but also redistributes it better through the house. Something to consider, if the radiators are not all warm.
Posted : 05/12/2011 7:15 am
a bit radical 🙂
Posted : 05/12/2011 7:30 am
 hora
Shirley radiatical? 😈
Posted : 05/12/2011 9:27 am
 Gunz
I've been tackling this in our 19th Century cottage (thick walls and draughty). So far the things that have made an immediately appraciable difference for minimum outlay have been the plastic film on windows and reflective insulation behind rads (Lidl have it on offer at the moment).
Posted : 05/12/2011 9:34 am
I was thinking of this for my house.
The 2 upstairs bedrooms have very old single radiators with no convection fins, so are not heating the rooms anywhere near as effectively as a single or double convector radiator.
One of these bedrooms is 4.5 square meters with 2.5m ceilings, so I'm pretty sure an old 300mm x 1500(?)mm radiator is pretty useless for a room this size.
The living room also has an old single radiator.
Posted : 05/12/2011 11:40 am
 hora
Re my earlier comment. I know I'll get laughed at but this is the toys/toy box that was uniformly and neatly put away and fully closed.
Wierd.
Posted : 05/12/2011 12:35 pm
Anyone looking to change radiator sizes should look at doing the calculations. A simple version is at:
[url= http://www.radcalcs.com/ ]http://www.radcalcs.com/[/url]
and
[url= http://www.theradiatorcompany.co.uk/heatoutput/ ]http://www.theradiatorcompany.co.uk/heatoutput/[/url]
There is no point in putting an oversized radiator in if it compensating for other problems like draughts or poor insulation, both of which are cheaper to fix than heating the room repeatedly.
How would one get 'proper ventilation' in a late 1800s stone-built terrace, incidentally? (Sorry for the hijack)
Posted : 05/12/2011 12:40 pm
TooTall, not sure if we've spoken off forum before, but is there any chance you could pop me an email (in profile). Cheers.
Posted : 05/12/2011 12:42 pm
[url= http://www.retrofitforthefuture.org/ ]http://www.retrofitforthefuture.org/[/url]
That has loads of good stuff for improving the energy efficiency of your house. Some of it is a bit OTT but pick out the bits that might be of use.
Cougar - can't say as you've not said how you live in the house. Questions like 'do you dry clothes on radiators, what windows do you have, open fires, how many live there, 24 hour occupancy or not, cook a lot, shower a lot' all matter.
Don - I'll mail you later when I get home.
Posted : 05/12/2011 1:50 pm
Clothes dry in tumble-drier or cistern cupboard, not rads. Non-vented double-glazing at the back, original (I'm guessing) single-glazed wood frames at the front. Gas fire in the back room. Two people, two bedrooms, out at work during the day, cook evenings and weekends, shower's in daily usage. The heating works but is archaic.
The front of the house suffers from damp. The problem started donkeys' years ago when I wasn't using the rooms and so just left them fallow with the doors closed, and a leaky gutter hasn't helped. Assuming these are the causes then I've 'fixed' them but the house isn't really drying out.
There's what looks like a vent brick on the front which has been covered over (plastered / papered) inside, and the gas people helpfully put a "vent brick" in the back room ("regulations, mate") by removing a great big stone from the wall and leaving a force nine gale belting through it. Needless to say, that got covered over fairly quickly too.
I've been toying with getting a dehumidifier for a while, but I don't know whether that's "the solution" or just a workaround.
Posted : 05/12/2011 2:04 pm
TooTall - thanks for those links, most useful.
Hardly surprising my downstairs bathroom is freezing so will probably replace electric towel warmer with one that runs off the central heating. Am really quite cross with myself for thinking that electric would be better and have wasted money. 🙁
Posted : 05/12/2011 2:10 pm
 hora
A decent plumber should be able to add in an extra radiator for £100 tops plus the cost of the radiator in the existing radiator network' (you could supply it yourself from screwfix etc).
There will be STW'ers who will say 'no! do it yourself its easy!' however I'd prefer someone to do it who does it every day.......not muppethands..
Posted : 05/12/2011 2:15 pm
