Why is my freezer.....
Why is my freezer....freezing up?
 Pook
We've had a bosch freezer for about 6 years. In the last year or so, it's started freezing up under the very bottom drawer - not frosting - freezing. We get a big slab of ice about 5mm thick every month or so on the very bottom. It's very satisfying to remove as it comes out in one with a bit of leverage, but I'd rather it didn't happen.
The seal looks ok.
What could be causing it and how can we prevent my frozen bottom?
Posted : 20/06/2025 7:11 am
Usual suspects are air getting in past the seal or condensation hole blocked.
Posted : 20/06/2025 7:19 am
I had this. The seal was OK, but the door wasn't quite closing properly. It was almost imperceptible, the door seemed to close fine until you took a very close look.  On mine there is some adjustment in the hinges, I tweaked them and all was well again.
Posted : 20/06/2025 7:22 am
It could also be very full up and the air can’t circulate. Take all the drawers out and check for an ice blockage in a plastic bit at the back.
Posted : 20/06/2025 7:28 am
