Evening
I have got a bit of a headache at the moment, so have taken some pills.. And while swallowing I wondered to myself why Paracetamol's don't have that sugary (almost tasty) coating that ibuprofen have?
I will admit its not a very important question, but a question nevertheless!
J
To stop kids thinking they are sweets??
I believe that death caused by paracetamol overdose is slow and particularly painful and unpleasant, so it's probably not a good idea to make eating them a pleasant experience.
I quite like the taste of paracetemol.
Can't say I take them often though.
In which case is paracetamol worse for you than ibuprofen? In larger/un-recommended doses..
Quite likely I would have thought. My understanding is that there is very little that can be done if someone has overdosed on paracetamol, it's apparently mostly a question of waiting to see if the person survives.
Cost. You're buying the cheap ones!
Paracetamol is a very commoditised API and cost is king - by reducing the excipients to not a lot more than talc or sodium carbonate + a few other bits for compressibility and dispersion, you can get most of the cost out.
Plus certain grades of Paracetamol compress into tablets really easily so you don't need much else.
Ibuprofen is a bit harder to get into a tablet and I think the tabletting process works better with Lactose which gives a sweeter flavour.
My job is very dull at times but hey ho, every so often I question pops up that I unfortunately know the answer to...as you can imagine I'm a hit at parties.
I found your pill-making expertise most interesting ๐
๐My job is very dull at times but hey ho, every so often I question pops up that I unfortunately know the answer to...as you can imagine I'm a hit at parties.
So did I, I never use Paracetamol, only the cheap Wilco ibuprofen, and I didn't know that Paracetamol didn't have a sugar coating.
Cheers. ๐
It depends on which brand I have, but one of the meds I take daily can either have the coating or not. It tastes vile without the coating.
As above, down to cost.
can you not hollow out some smarties/minstrels and grind up/sandpaper your paracetamols into a fine dust and pour it into the hollow smartie/minstrel casing. Maybe seal it with melted chocolate for that extra sugary kick?
It's a long and lingering one with plenty of time for reflection fear and regret. Most of the people awaiting liver transplants are for paracetamol related liver failure.
In addition to the production issues outlined in one of the previous posts, the coating on Ibuprofen is there because they are very acidic. The coating's primary function is the ease the passage of the tablet until it reaches the stomach. The acidity in very large doses of Ibuprofen can cause serious damage.
Paracetamol is less acidic so does not require the coating.
If you are exceeding the maximum dose on any OTC medicine, see a doctor.
Even when compared to alcohol abuse? ๐ฏ
Ibuprofen has a strange flavour, almost like detergent powder - anybody else noticed?
Zokes - yes. Paracetamol overdose can be achieved inadvertently over a sustained period, withou the dramatics of charging into the medicine cabinet and emptying the bottle.
If you're taking the stuff regularly (daily) at the higher end of the recommended dose then see a doctor NOW!
If you exceed the dose on a regular basis, by a small amount, then you are damaging your liver severely.
It's a great analgaesic but would never get licensed nowadays.
Plus which,AFAIK liver surgeons dont transplant alcoholics if they're still drinking.
Totally. Only takes a packet of paracetamol to **** your liver, rather than a lifetime of binge drinking. Some of the paracetamol damage will be deliberate suicide attempts with a very poor choice of method- as it does kill you, just a long time after you've changed your mind. But the other problem is paracetamol is hidden in a lot of produces so someone can take tablets for their headache, something for their runny nose and something for their cough without realising they've taken 3 max doses at once. Repeat that 4 times a day for the duration of a lurgy and that's a lot of liver attack in a short time.
Not quite true - you've a window of opportunity to give an antidote medicine.
DrP
Is that right ? I'd be surprised - surely chronic liver failure's plenty more common than acuteMost of the people awaiting liver transplants are for paracetamol related liver failure
You see that's what I thought made paracetamol so dangerous - that there was no effective antidote. So I'm glad to hear that's not the case.
Right-oh. Next time I have a headache I'll just get pished instead then ๐
But on a serious note, scary stuff!!!
As we've got the experts in.... IIRC, the max Brufen dose is 2400mg p/day. What does it do to you if you go over this and should it always be taken with food? Ta.
Presumably suffer from stomach ulceration, in the medium to long term
In order to avoid the above, yes (or at least not an empty stomach)
Ernie, you get up to maybe 12-24 hrs MAX to treat an overdose, after which it's too late (you're not healing the damage, you're mopping up the dangerous by-product of paracetamol as it gets metabolised, before it can do any damage).
Trouble is that you'd generally feel "fine" after a para overdose so may not even seek help; the damage becomes obvious after a couple of days
The more I read on this thread, the more genuinely scared I become....
boblo, for "any" licensed medicine, go [url= http://www.medicines.org.uk/emc/default.aspx ]Here[/url], type in the drug or brand name and view its SPC. Section 4.9 of that document deals with overdose
zokes - Member
I know! Why aren't the dangers of paracetamol more widely discussed!?
I've overdosed on paracetamol it was the taste of the sheer volume of grimness that made me throw up! If they were sugar coated I think I would have succeeded.
i'd take raise an eyebrow with the notion that transplant units are awash with people as a result of paracetamol use. is there data to back this up?
similarly a 12- 24 window just isn't true tho, broadly speaking, if you're coming in with a staggered overdose after 24 hours, your levels are high and your liver function is off, we'll be none too happy but we'll still be treating. hepatorenal syndrome - it's no fun.
here's the mhra stuff from last year, nomogram and all (check the pdfs for the detail)
http://www.mhra.gov.uk/Safetyinformation/DrugSafetyUpdate/CON185624
a question on domestic use tho - do they give weight guidelines? we give half dose for the under 50kg and i've seen toxicity not infrequently in wee old people taking their 'safe' dose
I'm sure I've had ones with the sugary coating before - does it not depend on the brand? I struggle to take ones without!
So what is a lethal dose of paracetamol? I know that stores are prohibited from selling more than two packets at a time, but what would it take for someone intent on killing themselves to visit serveral stores and buy packets at each one?
๐ฏ
All okay now, I hope?
whilst on this morbid topic* why do all the labels on stuff that can kill you if you ingest too much say "do not induce vomiting"
*interesting tho
Weird how what was considered an unimportant question by the OP can result in a very interesting thread, interesting stuff and more than a bit scary! Love this place sometimes.
I had to visit a fair few shops to get enough.
Better than they have been, I still regularly have to fight the urge to top myself but it makes life a bit spicy ๐
Because only some of it gets vomited out, and some gets 'pushed' into your digestive tract (imagine squeezing a tube of toothpaste with [b]two[/b] open ends)
This can then cause unpredictable absorption i.e. may shorten the 'antidote window' (basically speaking).
DrP
cheers DrP did not know vomiting was a "squeeze the middle of the tube" effort. Bit of a crap system for getting rid of toxins then, intelligent design my arse ๐
Glad to see the 'better'!!! Have you talked to someone about this, BTW? Someone who knows, that is, not us, obviously. ๐
I don't bother with Paracetamol, I find Ibuprofen so much more effective against headaches and general aches and pains....
Would bacteria grow on the sugar?
Swallow with water.
Not chew like a sweet.
Need it to dissolve in certain areas and not in the mouth or under the tongue.
I have spoken to hundreds of people over the years, I don't need them. Life's great at the moment got to roll with it ๐
Why not try the soluble paracetamol, I'm currently on 8 x 500mg per day and I don't find the taste too bad.
IIRC certain species ferment the stuff.
I'd say that "broadly speaking" it's very true.swiss01 - Member
Granted there's some small protective effect of parvolex to an already damaged liver (and even a tiny bit of evidence that iv dosing might undo some NABQI binding) but after a typical one-shot o/d, even 24hr is pushing your luck for any significant prevention
Staggered big overdoses are different but even then as a general rule the time from the clinically significant portion of the overdose (ie often 2nd "dose", that pushes the total amount into danger areas) would effectively start the clock (and from then, arguably, the window is shorter since glutathione is already depleted)
Incremental overdoses like taking 4-6g daily for some time in error are very different but don't really fit within the "popular" meaning of overdose as used here
IMO
