Why don't caravans ...
[Closed] Why don't caravans have four wheels then?
@slowoldman thanks, you had me giggling in the office there 🙂
Posted : 16/09/2019 2:57 pm
It’s as easy to have a badly loaded small trailer of waste bouncing about but the car can mask the drivers obliviousness to it. There’s not enough momentum or windage to bother the car.
The point I was making was however haphazardly i load my trailer it will always be pretty low to the ground with minimal windage. There's little requirement for additional training because its difficult to load it badly enough to cause a problem. A caravan loaded with a similar level of carelessness ends up upside down closing the motorway.
A 6.6m long caravan has a higher 'sail area to displacement ratio' than the average sailing boat*!
*sails, not including hull vs the side on area of a 6.6x2.5m rectangle weighing 1200kg or thereabout. Flat sides do not generate power like anaerofoil etc etc, this point is illustrative and doesnt stand up to pedantry.
Posted : 16/09/2019 3:59 pm
Because then they would be a van and useful.
Posted : 16/09/2019 7:33 pm
We have a winner.
Posted : 16/09/2019 7:37 pm
I dont think licencing is the problem, it’s caravans. Towing something small and heavy like a boat or trailer full of waste is easy
LOL You've clearly never towed many different types of boats before.
Posted : 16/09/2019 8:31 pm
A34 northbound near Didcot last night.
I saw that too, right mess.
Posted : 16/09/2019 8:52 pm
Fifth wheelers are probably the best solution but require a specific type of tow vehicle.
Is that right?
Posted : 16/09/2019 11:21 pm
I think you have just demonstrated that a specific type of tow vehicle is required.
Posted : 17/09/2019 12:14 am
What’s the difference between a corner and a bend?
About 50mph 😉
Posted : 17/09/2019 9:54 am
No-one has yet mentioned the benefits of a single axle for levelling have they?
Posted : 17/09/2019 10:09 am
Yes.
Posted : 17/09/2019 10:11 am
LOL You’ve clearly never towed many different types of boats before.
Nope, but I stand by my point that boats tend to be a lot smaller and more compact than caravans.
How often don you see a boat upside down on the motorway?
Posted : 17/09/2019 10:49 am
The difficulty comes in as:
Single axles cant be turned virtually on the spot(like a London taxi-turning circle less then 5 feet( but put all the load on 2 wheels)
Double axles more stable but tyre scrubbing and hesitance to micro adjust as the axles fight each other plus dont naturally follow..
Axle at each end.. MASSIVE TURNING CIRCLE and harder to manoeuvre..but more stable plus you can do 4 wheels on rear axle 2 on front etc..
Fifth wheel...well its specialist but harder to flip as it has to pull over 3 axles(yes 3 !!!! I do know this for a fact)
I'm used to moving big objects under tow and different designs different problems..but once you know how it's easy (imagine a car with its wheels on casters...like an ice hockey puck..that teaches you a lot about trailing axles and passive steering that goes on with axle arrangements..
NO ONE IS RIGHT OR WRONG ..its just different ideas of safe and controllable..
Posted : 17/09/2019 2:57 pm
Did my B&E license to tow a bigger caravan last year.
I learnt nothing. Experience is everything.
For me it's all about how I load the caravan. My current caravan has no nose weight. Very rear heavy. Need to put everything up the front end otherwise it's very unstable at 50mph.
Posted : 17/09/2019 3:30 pm
how often do you see one the right way up?
Unless we know the accidents/100,000 miles driven for caravan v boat towing it's a meaningless observation.
Posted : 17/09/2019 3:35 pm
No interest in owning a conventional caravan or motorhome, but have just spent a few minutes researching fifth wheel vans on the web 😂 If I had the cash spare I'd defo get one (plus a Merc X series to pull it) I'm guessing you could have a lot of 5-star breaks though for that combo.
Posted : 17/09/2019 3:36 pm
I’ve witnessed caravans fishtailing at 70mph and pulling the cars towing them 360 degrees before exploding into matchwood attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the dark near the Tannhäuser Gate.
Caravans are built as well as we can make them. But not to reverse.
Posted : 17/09/2019 7:18 pm
The week after I passed my test I was asked to transport our "dinghy" to a race event.
null
Posted : 17/09/2019 7:21 pm
I have towed large 3 axle 3.5T livestock trailers with a tractor and pick up, I regularly drive our smaller 2 axle livestock trailer with a small 4x4. I prefer 2 or 3 axle trailers to a single axle one which is a lot more twitchy.
We recently got a single axle caravan and it's very different. As people have said above the CoG is much higher, it is much more sensitive to side gusts and as it's a lot harder to see around and a lot longer than even a 3.5T livestock trailer it's a lot more awkward.
I was quite disappointed when I tried towing with the E class despite being a heavier and more powerful car and have gone back to towing with the freelander which is just better suited to towing.
Posted : 17/09/2019 8:27 pm
Ive seen first hand the trauma and tears inflicted on class 1 HGV drivers when faced with an A frame trailer, can you imagine the strain that would put on Jonathons marriage as he in a car with 2.1 kids his board wife and 3 pugs try to get that to Scarbados on a bank holiday weekend on the A64 .. the pain as he or she rips the bumper off after 31 failed attempts to stick it on the hard standing due to the weight of it,only to find out they have forgot the hook up lead. Bliss
Posted : 17/09/2019 9:05 pm
yeah the thought of trying to manoeuvre one of those farm trailers with a pivoting front axle fills me with dread.
I am guessing the normal rules on which way you turn to trigger the trailer turning go out of the window and you turn right to turn the trailer right rather than vice versa.
Posted : 17/09/2019 9:25 pm
It's not evidence, simply an anecdote, but I can say I've never been held up by a crashed caravan; whereas I was once held up by a crashed boat for four ****ing hours on the M6 on my way to a Polaris in the lakes. After work on a Friday night, having already driven 4 hours, and with a shitload of riding to do the next day.
Posted : 17/09/2019 9:29 pm
I don't fancy reversing one back down a singletrack road to the last passing-place after coming up against someone who doesn't know how to reverse their Ford fiesta and is sat in the middle of the road avoiding eye contact.
Posted : 17/09/2019 9:34 pm
but I can say I’ve never been held up by a crashed caravan
I have, or at least the caravan was partly responsible. On my way home on the M5 from picking up a car in Cornwall, approaching Taunton, my team leader, a couple of miles in front phoned me and asked where I was, and if possible to get off the motorway as soon as possible. As he was saying that I came over a slight rise to see brake lights coming on in front. I was about a mile short of the Taunton turn-off! What should have been a two and a bit hour drive took five hours, because Taunton became totally jammed, due to a car crash next to the Taunton Dean services heading North, and a car and caravan going sideways across all three southbound lanes near Wellington, so traffic from both sides was trying to squeeze through Taunton.
I’ve also been very close to being taken off the road by a poorly loaded ‘van coming towards me as I was heading home from Salisbury many years ago. It was on a stretch o road with high banks and beech trees either side, and the car and ‘van were coming uphill when the ‘van started to snake violently right in front of me. I had nowhere to go, I had barely time to touch the brakes, it was chance the ‘van swerved away just as we came level.
One of the most panic-inducing moments I’ve had in forty-odd years of driving, my heart rate didn’t drop for some time.
Posted : 17/09/2019 10:18 pm
I'm going to buck the trend and say I'd love to have a go at reversing a drawbar front trailer, but then I'm a bit weird in that I'll sometimes reverse blindside (the hard side in a van/truck) just to keep my eye in for when you need it. The easy option isn't always an option. You'll be glad when you are trapped in a road closure or accident and can turn/jackknife a 12 metre camper and horse trailer around in a 3 point turn whilst most of the cars are making a mess of it 🙂
Last time I saw a snake it was a driving instructor nailing his 4x4 off a roundabout with a horsebox (all stickered up with his driver training). He was hogging the outside lane ahead so someone nipped up the inside and caught him unawares, he corrected slightly and got a bit of a high speed wobble on, and then was forced to brake hard as both lanes were queuing for the next roundabout. I was too far back for any hilarious dash cam footage to put on his facebook page but he got pretty out of shape trying to slow down, ended up wobbling down the middle of both lanes and everyone suddenly gave him a lot of space...must have been humiliating as he queued towards the roundabout 🙂
Posted : 18/09/2019 8:06 am
It's never bothered me towing a caravan. You just need to think and observe a bit more, about your width and length. Other than that it just seems to follow me everywhere funnily enough. I am a bit twitchy in high winds though and it has caused me to slow down, when I can see the van lurching off to one side when a strong gust hits. Reversing has never been a problem for me either as long as you set yourself up well before starting the reverse and have a feel for it.
I have to say. One of my proudest moments. Getting done for speeding with the van on the back. I always like to counter peoples arguments about slow caravans with that story.
Posted : 18/09/2019 1:33 pm
Page 2 / 2
