Why doesn't Go...
[Closed] Why doesn't Google work in our office?
Multiple pc's running various OS's with assorted browers but they're all falling over their collective arses at opening the Google home page. All the other websites work fine, I know, I've clicked on them all, even the mucky ones, (especially the mucky the ones).
Virus checkers and spyware are turning up zip.
Posted : 01/07/2013 10:47 am
Have you tried http://www.downforeveryoneorjustme.com/
Posted : 01/07/2013 10:49 am
The only guess I can make is that Google has just changed the page to include a Cookies opt in button. Perhaps your system doesn't like it?
Posted : 01/07/2013 10:50 am
hmmm will have a persue some more
Posted : 01/07/2013 10:55 am
When you say falling over, what actually happens?
Google are naughty boys for compatibility sometimes.
Here's my suggestion, just as an experiment. On a device running Windows and IE, check that in the advanced settings 'use http 1.1' is ticked. See if that helps.
Posted : 01/07/2013 10:56 am
Is it the same for google.co.uk and google.com?
Every other page in the world opens apart from anything with Google innit. It just sits there trying to open but fails ๐Ÿ™
Gonna try unplugging the hub and attaching one direct to the router to see what happens.
Posted : 01/07/2013 11:10 am
Bing is my preferred search engine.
Posted : 01/07/2013 11:12 am
Have you tried turning them off and on again? ๐Ÿ˜‰
Posted : 01/07/2013 11:13 am
I knew there had to be one!
๐Ÿ™‚
Posted : 01/07/2013 11:17 am
I had this down here in Oz the other day at work. I didn't find a cure (apart from Bing), but all seemed normal the next day.
Posted : 01/07/2013 11:20 am
It started on a few last week and now know one can get it.
Why do I get a sudden urge to back up everything?
Posted : 01/07/2013 11:47 am
have you tried my suggestion?
Posted : 01/07/2013 11:53 am
Have you overporned it? Sometimes even google needs a rest.
Posted : 01/07/2013 11:55 am
DNS problem? I've had random pages refuse to load in the past when there's been something funky going on at our ISP's end.
Posted : 01/07/2013 11:56 am
samuri - yep, didn't have it
blokey here has had limited success flushing his dns but the same trick hasn't worked on the rest. I suspect the router is fudged after reading a similar story on bleepingcomputer
Posted : 01/07/2013 12:38 pm
Probably just GCHQ running a bit slow on processing your search data. ๐Ÿ˜‰
Posted : 01/07/2013 12:41 pm
I used to use Opera as my browser, but it suddenly stopped loading Google.
Checking the Opera support pages did not give much help so I switched back to Chrome.
Posted : 01/07/2013 12:55 pm
Just changed to our backup router/modem and it's doing the same.
[wavesfist]BT![/gggrrrrrr]
Posted : 01/07/2013 1:11 pm
Does this help?
http://www.isitdownrightnow.com/google.com.html
Not sure why you think it's BTs fault.
Posted : 01/07/2013 1:42 pm
You could always Ask Jeeves.
Erm.
Posted : 01/07/2013 1:44 pm
Had it at home, on our old XP desktop.
My W7 laptop was fine, likewise Android devices.
Was ok after a few hours.
Very strange.
Home desktop doesnt like yahoo mail either. Not the basic mail page, that works fine, but when the Wife logs in she uses that stupid enhanced email thing & the pc just goes into overdrive, with the fan spinning away & running slower as a slow thing.
Posted : 01/07/2013 2:09 pm
Is an nslookup on google.com returning correct ip?
Posted : 01/07/2013 2:48 pm
Try typing in the IP directly, to eliminate DNS or localhosts problems:
Copy/paste this into the address bar: 173.194.66.104
Posted : 01/07/2013 2:56 pm
aaaaaaand we're back in the room!
It has now mysteriously started working again. I made three attempts to get through to BT Business without any luck. It started working about 5mins after i'd requested yet another call-back.
So, if you have this problem, in summary:
Do Nothing.
Posted : 01/07/2013 3:50 pm
I now have this problem (it was working fine 5m ago).
PITA as I wanted to do some work on googledocs. Back to Wordpad!
Posted : 02/07/2013 6:35 am
 Haze
Have you tried hitting the same key repeatedly?
Posted : 02/07/2013 7:09 am
therealhoops - Member
Do Nothing.
Again, this points to a DNS record problem. The TTL for Google is 172800 seconds, or 48 hours.
As the cached values on each PC expire over that period, it will try and fetch the DNS record from your DNS server again, hence the PCs drop off one-by-one until the error is corrected at which point they all ping back into life.
Posted : 02/07/2013 7:21 am
All the DNS's were flushed at this end, even on the ones that don't Google as much but to no avail. I still reckon it was BT's fault.
Posted : 02/07/2013 9:50 am
Yes, that's exactly what I'm saying above. Flushing the DNS on client PCs or your local DNS server makes no difference if the DNS record upstream (i.e. your ISP) is incorrect, as you will simply keep fetching the incorrect DNS record again.
The quick test would have been to set one of the client PCs to use 8.8.8.8 as its DNS server, flush the DNS cache and see if it could suddenly resolve it.
Posted : 02/07/2013 9:54 am
oooooooooooooooohhhhhhhhhhhhhhhhhhhhh
that's worth remembering
thank you
Posted : 02/07/2013 10:46 am
For what it's worth we have a static IP with BT. Would that DNS test still work? I'm assfuming it would.
Posted : 02/07/2013 10:51 am
Assuming that your PCs can get unrestricted access out onto the internet, yes it should be fine.
Just make sure to set it back to automatic or whatever it was before when you're finished.
8.8.8.8 is one of Google's own public DNS servers BTW, it's usually pretty reliable.
Posted : 02/07/2013 11:21 am
Apparently there was back log on the whole internet as GCHQ's servers were a bit busy recently. They've upgraded to the latest version of Windows 8 and installed the latest Service Pack for 'MS Filter Everything Pro ++' and things are working again now...
Although searching for the Labour Party Leader still comes up as a 404 Page Not Found error ๐Ÿ˜‰
Posted : 02/07/2013 11:25 am
