Why are links to Am...
[Closed] Why are links to Amazon products not working?
Seen this a fair bit over the last couple of days - you see a preview of the product in the forum, then you click on the link and get this error message...
Posted : 17/09/2020 11:56 am
I saw it too not sure why, but it's a bit annoying.
Posted : 17/09/2020 12:27 pm
They went bust.
Posted : 17/09/2020 12:29 pm
Hmmm.. worked for me earlier.. maybe the trick is to only post the part of the address before the '?'
So if I post " www.amazon.co.uk / dp / 1905102941 /" without spaces I get...
https://www.amazon.co.uk/dp/1905102941/
That work?
Posted : 17/09/2020 12:51 pm
Posted : 17/09/2020 1:21 pm
It's broken, it has been for ages, and it's already in the bug tracker. It looks like it's going to be a little while before it gets looked at though, it's pretty low down on the to-do list.
As a workaround, if you post using the LINK button in the editor rather than just pasting raw text it works.
As a rule of thumb, when posting links 99% of the time the information after the ? is irrelevant bobbins and can be removed.
The reason you've probably not noticed either of these things till now is because I often clean then up manually when I see them.
Posted : 17/09/2020 2:45 pm
