Which router for fi...
[Closed] Which router for fibre? - wireless not required
Fibre being installed next week and I need a router. As the house wireless is handled by 2 x Airport Extremes, I'll not be using the router's wireless capabilities, so wireless doesn't even need to be a feature.
Any recommendations?
Posted : 17/06/2014 11:38 am
Won't your ISP be providing one?
Posted : 17/06/2014 11:46 am
Oh yeah..... I also have a ECI B-FOCUS V-2FUB/R REV.B modem that was left by the BT installer when he did another fibre installation for me.
Can I use this?
Posted : 17/06/2014 11:48 am
With fibre you need the modem AND a router, so I guess not. When I had a fibre install, the Openreach guy installed the modem and the ISP provided the router
Posted : 17/06/2014 11:52 am
On our first install (at another property) BT left the B-FOCUS V-2FUB/R REV. B and a homehub 4 but then the homehub 5 arrived an hour after he had gone and I just unplugged the modem and homehub 4 and plugged the homehub 5 in and off it went.
I should elaborate, all I need is a modem to connect to the fibre - all the internal network connections are dealt with by a sonicwall firewall.
If you don't need a username/password for a fibre connection then I guess the B-FOCUS modem will do the job.
Posted : 17/06/2014 12:24 pm
Ubiquiti do a good one for £80 or so. Else the Airport Extremes will do it nicely too.
Posted : 17/06/2014 12:42 pm
Did you not keep your Home Hub 5?
Posted : 17/06/2014 12:45 pm
You still need username and password AFAIK - the modem just terminates the connection and provides an access point onto the network, the router does the logging in to the service. AIUI that is.
Posted : 17/06/2014 12:48 pm
@ Simon_g
How did you set up the airport extreme to work with a BT Fibre modem?
I can't get my Timecapsule to work with my Openreach modem despite following sevral online "how to"s.
This may be ISP related though as TalkTalk don't offically support Apple products with their fibre broadband
Posted : 17/06/2014 1:00 pm
Currently connect via an airport extreme connected directly to the BT infinity modem- the settings are as follows:
Go into manual setup via the airport utility
On the 'internet' settings tab, make the following changes.
1 : 'Connect Using' select PPPoE
2 : 'Account Name' enter 'bthomehub@btbroadband.com'
3 : 'Password' and 'verify password' enter a single space (as in press the space bar once). There is no password, but for some reason it will not accept no password at all, and won't negotiate properly.
I don't have a service name set, and 'connection' is set to always on' with 'disconnect if idle' set to never.
Posted : 17/06/2014 2:03 pm
No, that was at an installation at another property - this is a new installation with Zen who do not supply a modem.
Dunno, when the homehub 5 arrived at the other installation it just needed plugging in - no setup required. Same with the HH4 which the engineer brought with him, no setup just plugged it in and it worked.
Posted : 17/06/2014 2:19 pm
Ah thought you may have too it with you.
BT is a rare exception of not needing a unique username and password.
Posted : 17/06/2014 2:23 pm
Ahhh, right. OK.
Posted : 17/06/2014 3:11 pm
woody2000 - Member
I got a new modem/router after taking the free upgrade to 50mb from virgin, it's the one box, which was quite good, let me get rid of some of the clutter.
Posted : 17/06/2014 3:15 pm
 apj
Zen support pages suggest that the BT engineer acting on their behalf will supply the necessary VDSL modem? So you shouldn't need anything else fibre-specific. And if the Sonicwall appliance does routing and the Airports act as your AP's, you should be all set.
Posted : 17/06/2014 3:56 pm
Yes, just saw that they've got instructions on how to set up the old Netgear DG834 which I've been using for about 10 years to connect using PPPoE - so I presume it will work.
Just checked the Sonicwall also and it too supports PPPoE so I think I could just cut out the Netgear and go Fibre > BT Modem > Sonicwall > LAN.
Posted : 17/06/2014 8:05 pm
