When is a photocopy...
[Closed] When is a photocopy not a photocopy?
It's really taken sombody all this time to notice that photocopiers distort characters, especially at small sizes, causing certain figures and letters to look like different ones?
I was aware of that thirty years ago... ๐Ÿ™„
Posted : 07/08/2013 10:39 am
It's more than distortion, it seems that it's actually doing OCR on the image and then reconstituting it.
Posted : 07/08/2013 10:55 am
They're all scanners and printers now, with a processor in between, hence data gets corrupted in the lossy process between the two ends.
Posted : 07/08/2013 10:58 am
[i]When is a photocopy not a photocopy?[/i]
When it's taken on a iBum chair?
Posted : 07/08/2013 11:00 am
Welcome to the digital world.
The only people surprised by this are really failing to understand exactly what is going on inside a scanner- it's not OCR'ing and then magically substituting characters, it's simply a compression artefact.
Granted it's rather an unfortunate one- one that should probably be avoided by Xerox choosing an appropriate amount of compression in the software!
Posted : 07/08/2013 11:12 am
Numbers were randomly being altered, with 6 and 8 proving especially susceptible.
That's not randomly then is it.
Posted : 07/08/2013 11:27 am
theroadwarrior - Member
It's a strange artifact though, I reckon they are doing pattern matching, the scanner effectively learning the font as it goes through the document, replacing subsequent uses of the same(!) letters with just a pointer back to the first instance.
So in a way, it's closer to deduping rather than a traditional lossy compression algorithm like JPG. Very clever, but obviously needs more tuning!
Posted : 07/08/2013 11:34 am
No that's not right, the compression format involved actually does OCR to find characters, so if the OCR has an error between similar characters like 6 and 8, then a completely wrong character gets put in. It is a symbol based compression format. Nothing like what is traditionally thought of as a compression artifact.
http://en.wikipedia.org/wiki/JBIG2
Posted : 07/08/2013 11:38 am
Why it is worse than blurred figures and traditional compression artefacts is that an error is not obviously blurred and hard to read, it comes out as a perfectly rendered but wrong symbol.
Posted : 07/08/2013 11:42 am
Yup, see the 3rd line - that's not a blurry 6, that's an 8. That's not a traditional compression artifact, it's an OCR error.
Posted : 07/08/2013 12:21 pm
No good for photocopying bank notes then...
Posted : 07/08/2013 12:26 pm
I've never had much luck with my fake ยฃ6 notes anyway...
Posted : 07/08/2013 12:29 pm
My god, what if someone photocopies an Excel spreadsheet......!
Posted : 07/08/2013 12:39 pm
Don't be silly, you can never get the laptop screen to sit flat enough on the copier.
Posted : 07/08/2013 2:30 pm
you'd do better to copy them into ยฃ8 notes ๐Ÿ˜‰
Posted : 07/08/2013 2:37 pm
