Community
What would you use?
[Closed] What would you use?
If you had to cut a 4mm square channel all the way round a centre of a few rollerblade wheels? The wheels are plastic but the cut needs to be accurate and smooth. My best idea so far to attach the wheel to a electric drill and spin it while using a dremmel to cut it. Who's got a better idea?
Posted : 23/11/2013 10:40 pm
Do you know anyone with a lathe?
Posted : 23/11/2013 10:44 pm
INto soft plastic?
Good luck with high speeds.
Posted : 23/11/2013 10:45 pm
wouldn't bother with the dremel you're just introducing one spinning thing to another. If you want accurate and smooth then you want to be cutting the groove with not grinding it - if you're spinning it on the drill you're effectively making a lathe. If you can clamp the drill securely you need to arrange some sort of secure tool rest then use a chisel to cut the groove.
Make sure you properly know what you are doing (if you have't used a lathe before) and make sure your eyes and all your arteries and anything else you would want a flying chisel jammed through are properly protected.
Posted : 23/11/2013 10:49 pm
A good point, well made.
Posted : 24/11/2013 2:00 am
