To wear through the winter. Need to be warm, waterproof and grippy.
Normal gloves and a plastic ball launcher thing
The slobberyness of the ball gets grim quite quickly... the ball launcher is perfect for dealing with that!
FYI, a tennis ball (and therefore the ball end of the tennis ball launcher) fits brilliant in a bottle cage!
[url] http://www.cleaningspot.co.uk/acatalog/Sealskinz-Duty-waterproof-glove--Ultra-grip--Black-DG751.html#SID=165 [/url]
i got a 80p ball lobber from B&M thought it was decent till i saw a guy on the park with one that fired his ball into orbit!! what the hell that thing was!? was like Rookie of the Year!
[url= https://www.screwfix.com/p/skytec-argon-thermal-argon-thermal-grip-gloves-black-x-large/64916 ]Cheap and cheerful winter glove[/url]
Normal gloves with disposable latex gloves over the top? Something biodegradable like this? Could double up as emergency poo bags too.
https://www.creamsupplies.co.uk/biodegradable-powder-free-latex-gloves-pack-of-100-large
Screwfix take a look
I carry two tennis balls. One gets thrown each time via a ball launcher - the other remains dry, in my hand, and is used as bait to induce the wee dug to drop her slobber coated ball somewhere near my feet. Slobber covered ball then launched off in a random direction. No special gloves required
Can't use a ball thrower as I can't use tennis balls as he chews through them in 30 seconds and the throwers don't fit the solid rubber balls that I have to use.
ah - we use posh tennis balls - - they seem to last longer than the cheapo ones... still from sports direct mind you, just 85p each...the posh ones seem to be more resilientto chomping
Yeah, cheap ones are brittle, good ones are supple
I'm sure you can get more durable balls and a ball launcher, sure I've seen them before
3 tennis balls from the £1 shop last a few minutes. Good ones last ages
I'd really like a decent launcher - the dog likes a run... any recommendations ?
Kong squeeky dog tennis balls last longer than[i] actual[/i] tennis balls - unless the stupid terrier gets hold of it.
[url= https://www.petplanet.co.uk/product.asp?dept_id=237&pf_id=70280&ptm_source=google&ptm_medium=shopping&ptm_campaign=under10_70280&campaign=324014531&adgroup=24641945531&content=214012163233&keyword=&gclid=CjwKCAjwgvfOBRB7EiwAeP7ehp4Ngr3S1Jo93mZVQdlBunmF8i1cxYO27ayQF_iDjOOffywX1IVl7RoC22AQAvD_BwE ]This gets good reviews.[/url]
But you can't beat a standard ball flinger for utility. Th Kong stuff is all pretty robust.
Anything less than a solid rubber ball will not last more than a minute with mine. Trust me I've tried allsorts, including proper tennis balls. Plus the good thing about the solid rubber ones is they go really far when thrown by hand.
You don’t own a Border Terrier.
Aldi ski gloves OP.
Arco do some of these :
[url= https://www.arco.co.uk/products/1235500 ]Waterproof handling gloves.[/url]
I have used them and they are not massively warm, but definitely waterproof. At £4 they may be worth a punt.
Ball thrower + heat gun = possible re-sized for different balls?
Probably one of these. The proper balls are expensive but worth it to tire out an energetic dog. We use proper tennis balls from sports direct also. (They fit the above)
+ 1 Drac. My flinging the ball game basically involves keeping it away from Hooch, my border x JR, so that the big dopey black dog can get some exercise.
I use cutis club most of the year but cutis pro when it gets nippy
Hard wearing, easy to clean and leave your fingers free
Balls - 'chuckit' ones are excellent and last ages. If you use tennis balls grit and dirt will collect in the fibres and create a sandpaper effect on teeth = expensive vet / dental bills.
Launcher - cheap one from generic cheap store - the chuckit balls are the same size as tennis balls.
Gloves - 'Sealskinz all seasons glove' these have lasted me years of dog saliva / cold weather abuse and are still waterproof
