What strings for dr...
[Closed] What strings for drop C please....
My understanding is that, as a general rule of thumb, you go 1 thou for each semitone.
I normally play 10-46 so 12-xx I dunno.
Any advice?
TVM
SB
Posted : 11/03/2011 5:28 pm
Newtone strings do special 'Drop tuning' sets which have a thicker core but are the same guage as a 'normal' set, basically means that when they're drop tuned they have the same tension as a standard tuned set. Used their bass sets for a couple of years now, Drop C with a 105 guage (compared to the 130s/135s I was using before) is brilliant!
[url] http://www.newtonestrings.com/ [/url]
Handmade to order in the UK, usually takes a couple of weeks and slighty more expensive but definitely worth it imo.
EDIT - can see they do a Drop D set as standard would give them a ring, sure they could do it for you!
Posted : 11/03/2011 5:34 pm
is it c,g,c,f,e,d (low to high)am not too great with guitar theory.i think that rose of sharyn by killswitch engaged was tuned to dropped c.when i attempted to tune to that i was on 9-42's .i reckon that 12's would be bang on the money.
Posted : 11/03/2011 5:36 pm
Thicker guage may require some nut and bridge work - one reason the Newtones are so good!
Posted : 11/03/2011 5:38 pm
@lifer - yes, tried some 11-52s against the nut on my guitar. It would need some work with a file. Will have a closer look at the newtones. Thanks.
Posted : 11/03/2011 6:03 pm
elixers. still the newtone sound interesting
Posted : 11/03/2011 6:05 pm
