What light fitting ...
[Closed] What light fitting for my bathroom??
4 Users
 DrP
DrP is not 10% clear on this..I've looked at the regs, but want to check..
Our ceiling is 240cm high, with a 'normal rose' in their at present. The edge of the shower cubicle is 20cm away (horizontally) from the light fitting, but of course is far below it.
I believe this would be a 'no zone' area (not 0, 1, 2, or 3), hence may not need IP44 rated lights...
Am I right?
Show your working for bonus points..
DrP
Posted : 21/09/2016 8:54 am
Whats the difference in price and or aesthetics of the different light fitting you've seen ?
ie ... just put in IP44 and have done with it.... and chances are, the fittings cosmetic looks will last longer.
No one likes a rusty ring on their celling .... 😀
Posted : 21/09/2016 9:05 am
Am I right?
It depends on the length of the rose, anything longer than 150mm (TOTAL) and I think you'd be in Zone 2 as the light source will need to be higher than 2250mm, I think.
http://www.thelightingsuperstore.co.uk/bathroom-lighting-zones
That said just put in an IP44 rated fitting like Ro5ey said as it will be much more likely to withstand the damp atmosphere.
Posted : 21/09/2016 9:15 am
 DrP
This is kind of what I was thinking too...
I just wanted to confirm my thoughts!
DrP
Posted : 21/09/2016 9:29 am
Surely the Lumen output and beam spread will be the deciding factor?
Posted : 21/09/2016 12:02 pm
 DrP
I'm aiming for 2500 lumen, wide beam, cable free design... Really makes the shower times come alive....!
DrP
Posted : 21/09/2016 12:34 pm
