What is the standar...
[Closed] What is the standard size for socket set fittings?
Not at home to check but want some bigger sockets (>14mm). I have a couple of bog standard sets at home (which both go to 13mm). Is the fitting on the wrench likely to be 1/4'' or 3/8''?
Posted : 26/01/2018 11:09 am
Most likely to be 1/4" if the existing set only goes up to 13mm.
Posted : 26/01/2018 11:17 am
3/8 will get you to 19mm
Posted : 26/01/2018 11:21 am
This is what I have seen. I guess I could just get an adapter to save buying a new wrench but I worry it might make things difficult in confined spaces.
https://www.screwfix.com/p/forge-steel-socket-set-3-8-15-pieces/1617c
Posted : 26/01/2018 11:26 am
Yeah, probably a 3/8
Just bought a 26mm for doing forks and they only came in 1/2", soย  I bought one of these
[damn this new forum!]
One of these -
https://www.ebay.co.uk/itm/3-8-Female-to-1-2-Male-socket-adaptor-use-1-2-drive-sockets-with-3-8-ratchet/132461257837
So I can use with my existing torque wrench (took me a while to find one, so thought it might be useful to share ๐Ÿ™‚ )
Posted : 26/01/2018 11:31 am
If you want something reasonable quality then halfords often have a good deal on socket sets. If you are going up a size then it's worth getting a new wrench too.
3/8 'standard' size, 1/4 is for finer stuff as it won't take a massive amount of force ( have snapped 1/4" drive stuff before & 3/8" when working on the van ( snap on 18") breaker bar )
1/2" is for heavier duty stuff ( cars etc)
Posted : 26/01/2018 11:39 am
