What have we dug up...
What have we dug up?
Digging up hte garden has discovered a thing. some kind of drain water connection thingy?
has a steel lid that is clamped down via 4 studs. in the centre of the lid is a threaded support (female) ready for something to go in but no idea what.
Vertically mounted. any guesses?
Posted : 08/04/2024 4:12 pm
Since you're a Killer I opened this thread slowly.
Posted : 08/04/2024 4:14 pm
kayak23, fasthaggis, kayak23 and 1 people reacted
[url= https://i.postimg.cc/HksmG2qC/0fb108fe-4d65-49a8-a660-9abc01c5f9ff.jp g" target="_blank">https://i.postimg.cc/HksmG2qC/0fb108fe-4d65-49a8-a660-9abc01c5f9ff.jp g"/> [/img][/url]
Posted : 08/04/2024 4:15 pm
Are there random numbers appearing on a screen nearby?
Posted : 08/04/2024 4:18 pm
oldnpastit, thepurist, thepurist and 1 people reacted
Over engineered DIY rotary washing line thingy?
sboardman, fasthaggis, kelvin and 3 people reacted
 a11y
Undo the bolts then tell us. what's the worst that could happen?
(dibs on your bikes)
Posted : 08/04/2024 4:21 pm
somafunk, Bunnyhop, Bunnyhop and 1 people reacted
https://media4.giphy.com/media/dBFdPL9iTLRfi/200.webp
Posted : 08/04/2024 4:23 pm
blokeuptheroad, sboardman, leffeboy and 9 people reacted
That's a NATO standard machine gun support, as used by the Operation Gladio stay behind networks in case of democractic election resulting in a government that falls behind the standards of the overlords
Posted : 08/04/2024 4:25 pm
supernova, oldnpastit, supernova and 1 people reacted
something that shouldn't be that close to the surface ?
Posted : 08/04/2024 4:27 pm
PT shaft of a vertically buried tractor
Posted : 08/04/2024 4:32 pm
 10
Artisan frozen sausage mount.
Posted : 08/04/2024 4:33 pm
towpathman, reeksy, blokeuptheroad and 43 people reacted
base for an old manual water pump ? probably got a 1-way valve under it
Posted : 08/04/2024 4:42 pm
Home made mount for something, that's my guess. Doesn't look like anything water related but who knows what bodges have been done in the past.
Posted : 08/04/2024 4:43 pm
You don't live next door to Colin Furze do you?
sboardman, pk13, Tom83 and 5 people reacted
Definitely an early contender for Thread of the Week!
Posted : 08/04/2024 4:48 pm
Breather pipe to a vampire, bomber wielding, baby robins coffin.
Dunno if it’s just me but I’d be very tempted to slowly undo the four retaining bolts and see what happens/doesn’t happen.
Disclaimer : this way of thinking has not always worked out well for me in the past so don’t blame myself if you empty the North Sea of gas.
Posted : 08/04/2024 4:58 pm
leffeboy, fatmax, kimbers and 3 people reacted
Have you dug down around it to see if it's connected to pipes?
Posted : 08/04/2024 5:04 pm
Thrunge gasket (imperial) innit.
The original machine had a base plate of prefabulated aluminite, surmounted by a malleable logarithmic casing in such a way that the two main spurving bearings were in a direct line with the pentametric fan. The latter consisted simply of six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented. The main winding was of the normal lotus-o-delta type placed in panendermic semi-bovoid slots in the stator, every seventh conductor being connected by a nonreversible tremie pipe to the differential girdlespring on the “up” end of the grammeters.
Posted : 08/04/2024 5:08 pm
Swing ball set. Pro edition.
Posted : 08/04/2024 6:18 pm
towpathman, binman, daviek and 17 people reacted
Ordnance Survey Fundamental Benchmark
(It's not that, I am well aware)
Posted : 08/04/2024 6:20 pm
Borehole cap for groundwater / ground gas monitoring. Is it a relatively new development?
Or a portal direct to the underworld.
Posted : 08/04/2024 6:33 pm
Pyro and Pyro reacted
.... keep digging.
Posted : 08/04/2024 6:56 pm
breninbeener, somafunk, gecko76 and 5 people reacted
 kcr
Google image search using your pic comes back with some interesting suggestions:
Posted : 08/04/2024 7:18 pm
I think it's the base for an aerial.
Posted : 08/04/2024 7:39 pm
I think it's the valve that controls the supply of food to the hamsters.
Posted : 08/04/2024 7:43 pm
J-R and J-R reacted
Hate to be serious but yellow paint and four bolts says old cast iron gas main to me.
Posted : 08/04/2024 7:46 pm
+1 for borehole cap or an old well cap
Posted : 08/04/2024 8:04 pm
Just to be clear here, is the mount artisanal or the sausages?
Posted : 08/04/2024 9:24 pm
stwhannah and stwhannah reacted
It's the top of a mast from a Clanger musical boat.
The Iron Chicken will be along soon to take it back for repair.
Posted : 08/04/2024 9:35 pm
It's a borehole. I've seen hundreds of them and inspect them for the environment agency.
Here's one I photographed last week.
Screenshot_20240408-212417
Posted : 08/04/2024 10:25 pm
 10
I hadn't thought that far ahead. Which may also be Killer's excuse if they undo the bolts....
Posted : 08/04/2024 10:27 pm
Its cracked anyway. You can see the big crack where a stud is
Dig round it some more...
You get all the best jobs Adam.
I haven't stepped out off the office in months.
Posted : 08/04/2024 10:28 pm
ads678 and ads678 reacted
@joshvegas I haven't been into the new Leeds office since they moved last Oct as I'm pretty much always on site at the moment!
Finished doing EA stuff now though and starting on IDB stuff.
Posted : 08/04/2024 10:32 pm
ads678 - assume they cap them for safety? In which case, nerdily interested to know why the hole in top, assume to prevent any gas build up?
Posted : 08/04/2024 10:58 pm
Following with interest. Interesting find. I’d be unable to rebury it too. Curiosity can be risky tho.
If it’s the borehole ads678 describes (seems v likely) is that going down to the water table. Does it gush, potentially I wonder?
Remember to get the Mrs to video as you take the bolts out. Might make you a few p on YouTube.
Hope it’s not gas!
Better have a bung ready.
Posted : 08/04/2024 11:10 pm
The ones I've been looking at are ground water boreholes rather than gas. The hole in the top is to attach a tap/valve to. Not all have the valve attached though. Think it depends on ground water levels or something, some would have water spewing out of the hole if the valve wasn't fitted! I don't deal with the actual monitoring though, just checking the infrastructure.
The one in the OP looks like it's decommissioned and it isn't used anymore.....one of the things I've been doing is trying to help the EA figure what they have and what is still in use....
@killer - where about are you btw?
Posted : 08/04/2024 11:21 pm
This is one with the valve fitted.
Screenshot_20240408-222829
Posted : 08/04/2024 11:30 pm
You could see if it is on the BGS borehole map - BGS
Posted : 08/04/2024 11:35 pm
ads678 – assume they cap them for safety? In which case, nerdily interested to know why the hole in top, assume to prevent any gas build up?
Stop stuff getting in, I have lifted a family of newts out a ground water borehole missing a tap before. Pulled out the bailer sampler and there were three newts staring out at me.
The hole at the top is for gas monitoring fitted with a tap you keep it sealed and fit the monitor. At least that's all I have ever used it for. You might feasibly get the dip meter in, big tape measure with a sensor at the end tells you where the water level is. You would also get a narrow bore water sampler in.
I think generally, Adam would confirm, they all pretty much get the same cap for convenience.
I have only ever used them for water quality monitoring.
Posted : 09/04/2024 8:28 am
You could see if it is on the BGS borehole map – BGS
And there's another day lost 😂
Posted : 09/04/2024 11:23 am
thelawman and thelawman reacted
If you need help I’m sure there is a boreholes anonymous group near you to provide support with your addiction. 😉
Posted : 09/04/2024 11:50 am
Yes, it’s quite fascinating to see what’s in your area. Around me (Co. Durham) you can see where former pits were because there are clusters of holes with confidential data on the depth (the black dots), and lines where surveying was done for roads (bypasses) that were never built.
Posted : 09/04/2024 11:53 am
Well, despite having just managed about £3.5m of ground investigation I didn't recognise that as a borehole! The ones I get to see are a bit 'neater' than that. (I'd probably complain tbh)
Still think it's a homemade washing line holder from an old borehole cap. 😉
Posted : 09/04/2024 12:01 pm
I was going to say that but was slightly worried I might be labelled as a bit dull…
I did once discuss a prospective building plot with somebody who was thinking of selling a bit of garden. He was telling me how great the ground was for foundations as his house was built on bedrock. By chance (or was it?) there were a couple of very old boreholes nearby. Indeed his house was clearly built on a nice outcrop, just 20 or 30 metres away it was a load of crappy rubble and shale.
Posted : 09/04/2024 12:02 pm
I think Josh is right, they all have pretty much the same type of cap, just different sizes, as some have multiple actual BH's under the cap.
Posted : 09/04/2024 12:11 pm
This was found in Stapleford between Derby and Nottingham. Now hunting through the map to see if its mapped
Posted : 09/04/2024 12:28 pm
Well can't find it on the BGS map. so maybe its even older? or back to the clandestine sausage mounts division
Posted : 09/04/2024 12:34 pm
Boar hole sausages
Posted : 09/04/2024 12:37 pm
Killer if you search NL's side by side maps you might get an idea of what was nearby previously. I think it's near the Attenborough nature resever? Probably exploring for gravel deposits.
Word of warning though.. if you though the bags viewer was distracting...
Posted : 09/04/2024 12:41 pm
@killer - I've just checked on the EA mapping and I can see 2 BH's near Stapleford. If you PM me with a more accurate location I'll see if any of them are yours. Actually I'll PM you with the rough locations i've found.
I don't deal with that area so don;t know who the contact is, but if it is one of those it might be worth contacting the EA to see if they can do anything about it.
Posted : 09/04/2024 12:53 pm
