What hammer for..
[Closed] What hammer for..
car keys. We've moved into a new flat. The GF managed to shut the car key in the fire door and bent it. Thinking of smacking it with a hammer to straighten it, but don't want to fatigue the metal and end up snapping it in the barrel. Looks like it may bent slightly horizontally too?
Hints/tips?
Posted : 11/08/2013 2:52 pm
Personally I'd straighten it in a vice...
Posted : 11/08/2013 2:55 pm
+1 for using a vice.
Posted : 11/08/2013 3:08 pm
You're bending it back no matter if you use a vice or a hammer. Just make sure you do it on a solid, flat surface. Hammer with a nice flat face with gentle taps letting the hammer weight do the work.
Or get a new key.
Posted : 11/08/2013 3:12 pm
Whatever you do, once it's broken, don't put the broken end I to the ignition barrel as a 'way of getting home' it doesn't work (according to a friend of mine ๐Ÿ˜ณ )
Posted : 11/08/2013 3:42 pm
Renault key? Even if it's not, the metal part can probably be copied at any normal key cutter. So straightening it out then getting a replacement made may well be fairly quick n easy
Posted : 11/08/2013 3:45 pm
A pair of pliers or molegrips should be enough. Make sure you order another key ASAP!
Posted : 11/08/2013 3:46 pm
I wouldn't use it unless I really had to. It may last forever, or snap first time you use it.
Posted : 11/08/2013 3:48 pm
 joat
As kayak says. But if you can do it across the angle on a vice or some such one small bit at a time it shouldn't fatigue it.
Posted : 11/08/2013 3:49 pm
Dial 0800-Uri-Geller.
Posted : 11/08/2013 5:11 pm
Warm the metal up a bit before using the hammer etc ... or you will break it.
Posted : 11/08/2013 5:15 pm
Cheers for all the advice. Will avoid a big hammer.. for now.
Will nip into Timpson tomorrow.
Posted : 11/08/2013 5:42 pm
My remote key broke so today I ordered a repair kit from these dudes...
[url= http://www.expresskeyfobs.co.uk/?zenid=38e6f8824d6ea94a23fc5cd31b1e4184 ]key dudes[/url]
You can get the whole fob with a new blade blank so you can then take it to timpsons and just get it cut.
Posted : 11/08/2013 6:05 pm
That's a fairly gentle bend, you could almost straighten it with your fingers, but gentle taps on something fairly solid like a chopping board should do the trick.
Posted : 11/08/2013 10:24 pm
[quote=chewkw ]Warm the metal up a bit before using the hammer etc ... or you will break it.
Warm it up and you risk melting the electronics.
Posted : 11/08/2013 10:26 pm
I doubt it will break if you follow Kayaks advice and be gentle, top link to key dudes BTW
Posted : 12/08/2013 7:41 am
I had something similar last year. Straighten it and get it copied while still in one piece.
I kept using mine and it snapped in the lock.
Posted : 12/08/2013 8:33 am
I'd suggest a vice AND a pair of liners for the vice - A couple of bit of angle-iron or similar. You only want to bend it BACK, not beyond - the more it bends the more it will fatigue, so try to get it right first time.
Regardless, brass is not know for fatigue resistance, I think it's used in keys because it it "self lubricating". Get a new one!
Posted : 12/08/2013 8:35 am
