I've been buiding a garden pavilion with some recycled bus shelter glass. A couple of the panes have a white bloom that is on the surface, possibly as a result of water having been trapped between the sheets as they have been stored outdoors.
Is there a glass cleaning product that will remove this bloom?
Is it limescale? try the stuff for cleaning shower screens
I find washing powder to be a very effective cleaner of soiled glass, worth a try i suppose
Note: if you have any cuts on your hands you will know about it, stingy
Really? You must post up some pics so we can follow its progress.
something like this.
[img] http://www.partmaster.co.uk/cgi-bin/image.pl?b=5031680552294&s=480&t=z&i=0 [/img]
I use it on my hob funnily enough with a blade scraper and it polishes up dandy.
If its bus shelter glass it might have some sort of laminated on/ fired on coating to make it less graffiti-able or self cleaning or some other technobunk.
If its some sort of film it might have absorbed trapped water - let it sit for a while and see if it clears, going at it with anything abrasive might make things worse rather than better.
I clean bus shelters for a living and staining is usually limescale .I use a windowcleaning scraper blade to remove this ,its like a razor ,dont use a stanley blade as they scratch the glass.I dont clean any shelters with coatings on .Such stuff exists but would be to expensive once the local ****less neds have smashed a few panes
Edric 64 No niche is too niche for STW.
Do you have a pic of one of these.
doubt it will be limescale in Fife, unless the glass was imported from doon sooth.
[url= http://www.windowcleancentre.co.uk/productdetails.aspx?ProductID=156&SectionID=22 ]http://www.windowcleancentre.co.uk/productdetails.aspx?ProductID=156&SectionID=22[/url]
Handfull of scrunched up newspaper works well and recyle it after use.
