Im putting a small fence on top of a block wall (blocks laid on the flat).
I have these..
[URL= http://i219.photobucket.com/albums/cc310/jenga101/Mobile%20Uploads/IMG-20170318-WA0002_zps1txxor5y.jpe g" target="_blank">
http://i219.photobucket.com/albums/cc310/jenga101/Mobile%20Uploads/IMG-20170318-WA0002_zps1txxor5y.jpe g"/> [/IMG][/URL]
So whats the best way of fixing to the wall??
Fence posts will 75mm and 750mm high. Holes in bracket are 10mm.
Screws and plugs / concrete screw bolt / expanding bolts?
I'd be using sleeved anchor bolts (and a new drill bit).
If I had dozens to fix, didn't worry about removal and had time rather than money, I'd consider cutting threaded rod and use resin & nuts.
Masonry Torx Frame Fixing Screws are my favourite for screwing into blocks: http://www.toolstation.com/shop/p60986
I'd use anchor bolts too. The drilled holes are likely to be rough and possibly crumbly so screws alone won't hold a post that could be under a lot of strain.
I'd also space the posts a bit closer than normal.
I used threaded rod, drilled holes in the block and fixed with resin (but some of mine was into very old brick so I was worried about ushering expansion bolts)
Proper masonry ones will. I've fitted loads and they are rock solidscrews alone won't hold a post that could be under a lot of strain.
These. Nothing shifts them, and dead simple to use.
They look good.. I presume they are ok for exterior use.
Is it just a case of drilling a hole and impact driver them in??
I was concerned expanding bolts would crack the blocks when tightened.
Would a concrete / masonry bolt be overkill..(never had any experience of self tapping type bolts)
http://www.toolstation.com/shop/p64877?table=no
The main thing is how close to the edge of the block is the fixing? (And to a lesser degree thickness, when laid flat)
It's this that will determine whether you will need resin.
If close = resin
A bit close but not to close = masonry screws
Nowhere near = waz a sleeve anchor of some sort in
M8 hex head concrete screws around 90-100mm long
Something like this
http://www.screwfix.com/p/dewalt-blue-tip-concrete-screwbolt-hex-head-8-x-100mm-25-pack/49364?kpid=KINASEKPID&cm_mmc=GoogleLocal-_-Datafeed-_-Screws%252C%2520Nails%2520and%2520Fixings&cm_mmc=Google-_-Product%2520Listing%2520Ads-_-Sales%2520Tracking-_-sales%2520tracking%2520url&gclid=CMDNhorO4tICFU2eGwodvlkFCw
