Weights or resistan...
[Closed] Weights or resistance bands
I want something I can use for short, simple workouts at home, that doesn't take up too much space.
I was thinking maybe a small set of dumbbells but most of them seem to come with limited weight options.
Any recommendations?
Posted : 11/04/2017 10:34 am
I've a pair of dumbbells that can take from 1Kg up to 30Kg possibly more, not sure how that's limiting?
Resistance bands need something pretty solid to attach to, IME they are more use for physio and secondary muscle groups.
Posted : 11/04/2017 10:37 am
Couple of kettlebells would see you right I would have thought.
You've not said what your goals are so it's a bit hard to say exactly.
Posted : 11/04/2017 11:04 am
That's my experience of resistance bands too.
When I say limiting: I mean the plates they come with.
Posted : 11/04/2017 11:06 am
Kettlebells would be dangerous in my living room.
Posted : 11/04/2017 11:07 am
Limiting as in the weight or in movement?
Do you want to start again and say *exactly* what you want and what problems you currently have with whatever kit you currently own or have access to?
Posted : 11/04/2017 11:12 am
Why?
You don't drop them.
Posted : 11/04/2017 11:16 am
Not particularly.
Posted : 11/04/2017 12:43 pm
Selectable dumbbells. You can get a set from Powerhouse Fitness for about £300, they take up the space of one pair, but give you a set of 5 - 7.5 - 10 - 12.5 - 15 - 17.5 - 20 - 22.5 - 25 - 27.5 - 30 - 32.5kg weights. This should be enough for most exercises.
If you haven't got room for a bench, get a Swiss ball instead.
Posted : 11/04/2017 1:47 pm
£300 for something the only function of which is to have mass is a bit of a rip off really.
Posted : 11/04/2017 1:52 pm
TRX bands
Posted : 11/04/2017 1:56 pm
A pull up bar £20 is your best bang for buck,then you have push ups that cost nowt, you could build an impressive physique with variations of pull ups and push ups.
Throw in some planks, bridges and pistol/shrimp squats and you have the full monty.
Posted : 11/04/2017 2:19 pm
