washing machine pcb...
[Closed] washing machine pcb?
Our 2 yr old washer dryer stopped working , just no power getting to it at all. Checked fuse its ok. So is this likely to be a new pcb needed or is there something else easy to check that it might be first?
Its a Beko WDX 8543130B not sure its worth sorting out but its seems a shame to sling it too as it was working well up untill complete power loss,
Thanks STW
Posted : 17/04/2020 2:26 pm
Have a look on https://www.ukwhitegoods.co.uk/forums/
There are professionals posting on there who will usually give free advice, often you can find the answer in existing threads. If you need parts, they sell them on the main site.
Posted : 17/04/2020 3:09 pm
Has it got an anti-flood switch at the bottom? These sometimes fill with water an shut it off.
Posted : 17/04/2020 3:31 pm
Have a good look at the forums, if you CBA, so much good info around.
Posted : 17/04/2020 4:14 pm
Thanks all,
Just found this, sounds like its a common problem with a cheap fix which some very helpfull engineer has taken the time to detail.
https://www.washerhelp.co.uk/forums/topic/2662-beko-wdx8543130w-no-lights-on/
Posted : 17/04/2020 6:20 pm
Oarsumz
Posted : 17/04/2020 7:33 pm
Fab
Posted : 17/04/2020 8:52 pm
