Community
washing machine lea...
[Closed] washing machine leaks after filter cleaning???!!
 jj55
Just had to remove the washing machine filter buried deep inside the back of my washing machine. Basically I had to remove a plastic jubilee clip, pull down a rubber housing off a nylon fitting.
Cleaned all ok, but now when it's all fitted back together the ******* thing keep leaking where the rubber housing is clipped onto the nylon fitting.
Any suggestions?
Not to self - next time buy one with a simple filter at the front!
Posted : 27/01/2013 2:42 pm
Had the same problem. Bit of plumbers ptfe tape round the nylon hose tail fitting and replacing plastic jubilee clip with metal one did the job for me. I assume the housing is not cracked or anything?
Posted : 27/01/2013 3:56 pm
 jj55
Yes thanks, housing looks ok. Just put a load of vaseline around the housing before clamping the rubber boot back on again. Seems to be working at the moment.....
Posted : 27/01/2013 4:55 pm
If that dont work, and if its a Hotpoint ...
Take out the plastic cage and remove locating tabs on the top - totally useless tabs but can somtimes stop the cage & sump seating on the drum. If the vaseline trick stopped the leak its not the vaseline, you just reseated it properly... ๐Ÿ˜‰
Posted : 27/01/2013 5:42 pm
replace the plastic clips for metal jubilee ones,the originals are only designed for one time use.
Posted : 27/01/2013 7:58 pm
