vw polo differentia...
[Closed] vw polo differential broken !!!!! help
hi
p reg polo 1.4 with 78 k on it
diff just broke prob due to sheared bolt
girlfriend is distraught sso jsurt looking for any gud advice
odr mechanics near bath / chippenham way
cheers
craig
Posted : 27/09/2011 12:21 am
Driveshaft sheared?
Posted : 27/09/2011 7:43 am
car can't be worth a lot, buy a new one
Posted : 27/09/2011 8:37 am
Diff is in the gearbox innit?
New gearbox time!
Posted : 27/09/2011 8:49 am
Scrapper time!
Posted : 27/09/2011 9:11 am
aye, if it is the diff then cost will probably be prohibitive to getting it fixed unless you can do it yourself? If it is a drive shaft then it is an easy fix.
Shame you are not closer to Bristol as if you did decide to scrap it I've got a student friend who needs a car on a very tight budget and a would teach him how to do it.
Posted : 27/09/2011 9:19 am
Not the biggest of jobs on a P-reg polo but the easiest fix would be to buy a 2nd hand box and stick it on. The job in itelf isnt that big and could be done in a matter of a couple of hours.
Posted : 27/09/2011 9:42 am
Get another gearbox from a breaker, then go to a clutch place and get a new clutch installed for £x amount, and ask them to stick the new box in when replacing the gearbox (which shouldn't cost you anything more) .
'Tis what we did.
Phone around mind, you wouldn't believe that some garages actually believed picking a different gearbox up off the floor was more work, and they wanted an extra few hundred quid!
Our local Mr. Clutch did ours.
Posted : 27/09/2011 10:58 am
that's not a bad idea about the clutch as it gets around the whole "we won't do it due to warranty blah blah blah" when fitting a 2nd hand box.
Posted : 27/09/2011 11:11 am
The daughter's gearbox failed on her P reg 120,000+ mile 1.4 Polo earlier in the year. My local garage got me a second hand gearbox and fitted it (they said that there were loads around due to the scrappage scheme) there was a bit of a problem due to different gear lever linkages.
Posted : 27/09/2011 11:47 am
Fitting a clutch with the gearbox off is a doddle!! Its getting the gearbox out which can be a PITA.
Posted : 27/09/2011 12:23 pm
Yup, good point Dibbs, some are rod linkage change and crap ones like ours were cable change.
Posted : 27/09/2011 12:37 pm
