Can any of the IT crowd on here recommend a good website of book for learning Visual Basic?
Been playing around with it on Visual Studio Express and I would like to learn a bit more.
Can anyone recommend a good website or textbook for an intermediate? A bit more than loads of "Hello World" type stuff but crazy complex and expecting good knowledge of over coding?
Hi
ot, sorry - suspect not what you want to hear, but all the guys at my place are now wanting to do C#, as they reckon VB is finished
*Could try popping down library and seeing if a author/style that suits you turns up - and could look at night school options if you want help.
library not a bad call. Miss the obvious sometimes!
Not worried about being up to date, just want to play around a bit. Used to be able to write some decent (for me!) Excel macros so thought VB would be the way to go.
Presumably you know about http://msdn.microsoft.com/en-us/library/dd492171.aspx
Thanks Towzer. I was aware but haven't used it for a few years when playing with Excel. Found it a bit hit and miss before. I'll give another go though.
Would like a decent book, find it easier to work with to.
For small projects google is your friend, find an example that does part of what you want.
I managed to use a text chat example so i could send programs to cnc machines.
As above, learn C# then move on to asp.net.
Youtube tuts are 10x easier than book learning.
I like this guy's vids:
http://www.youtube.com/user/ProgrammingKnowledge?feature=watch
don't waste our time with VB - and it would certainly be good if it was killed off.
VB.NET or C# makes little difference to me and I can switch between the two easily (although C# tends to pay a little more)... you are using the same .NET framework / libraries and it's with these where the important stuff happens. I quite like the Microsoft Step by Step books if they are still around (check online for the [errata] corrections as they tend to be quite error prone) after that the Certification exam guides can be quite good 'fun'.
p.s. note VB and VB.NET are too very different beasts.
When I accidentally got a job as an ASP.NET developer I taught myself from a pdf I found online. Once you have a little knowledge you'll end up just trawling stackoverflow questions for answers anyway...
There's advice and then there's giving away trade secrets!
