UV transmitting, Vi...
[Closed] UV transmitting, Visible absorbing filter. Procurement.
Looking for some filters for uv flash photography. Any ideas?
Posted : 12/07/2017 10:34 am
Science suppliers? Lee filters? Rosco? Cokin? Camera shop?
Posted : 12/07/2017 10:38 pm
This seems like a reasonable place to start:
http://www.uqgoptics.com/catalogue/Filters/SCHOTT_BANDPASS_FILTERS.aspx
Depends which part of the UV band you're interested in.
Posted : 13/07/2017 4:58 pm
don't most cameras have inbuilt UV and IR blocking filters?
I remember seeing some stuff where someone had modded an rx100 to remove the IR filters but it was a pretty involved process.
Posted : 13/07/2017 5:00 pm
You could try Edmund optics.
They'll have all sorts of filters but unlikely to be in a standard screw mount photography format. You could try combining a flat glass square filter with a mount like people use for ND filters.
As mentioned above I'm assuming you're already aware digital cameras will have an IR+UV cut filter fitted over the sensor.
Posted : 13/07/2017 7:05 pm
