I've got loads in the loft from multiple previous recarpetings. Anything I can do with it instead of just chucking it in the tip?
carpet the garage.
make a wig/ merkin
line the shed/garge/bike fettling corner?
The garage has already had a bike-fettling makeover, I painted the floor with garage floor paint.
open up a body disposal business.
use it to scale a barbed-wire fence
Roll it up and keep it in the loft until you move?
I've used bits to cover ground and keep weeds down before, but apparently this may not be a good idea due to chemicals in the carpet leeching out.
build some dirt jumps and carpet them?
Stick a couple of bits in the boot of your car. If you get stuck in snow, a bit of carpet under each of the driving wheels will often give you enough traction to get under way.
That's a good one, and you can use them to stand on while getting changed in the car park too.
Ah, changing mat, I like it.
make a tabbard!!
Warming the soil and supressing weeds in the garden/allotment. Put on freecycle.
used mine in the car boot for chucking dirty gear on top (mtb gear dirty dog,stuff for tip)Also if working under car put some down on ground to keep warmer /clean
A merkin?
Glue a piece to your chin, makes you look rugged.
I use a strip under my bike stand. Helps stop small items bouncing and disappearing between the flagstones on the patio. More comfortable to kneel on, too.
line the shed with it as a cheap form of insulation
carpet country lanes? helps with the traction on ice.
If they are a reasonable size see if there are any local charities/ recycling initiatives like [url= http://www.sprucecarpets.org.uk/ ]Spuce[/url] here in Glasgow. There are places that can run an edging round small sections of carpet to make rugs too.
is there enough to roll yourself up in it, then when guests arrive, have it dramatically unrolled so you end up at their feet?
cut small squares out & attach them to your feet. Then wherever you go, there's carpet underfoot
dig a hole in your garden and live the whole of next week as a trapdoor spider?
Dig a hole in you garden, or lift some floorboards, lay the carpet over it and wait for something hilarious to happen. Keep a camcorder handy
pond liner protecter
