uPVC Front Door £££...
[Closed] uPVC Front Door £££££??
as above really, how much have you paid to have supplied and fitted? Any recommendations on national companies? Cheers
Posted : 12/02/2011 3:04 pm
Don't get a uPVC one, they look horrid. Get an insulated composite door. Mine was £800 with a glass side panel thats almost the same size as the door.
Posted : 12/02/2011 3:41 pm
Yeah noticed the composite ones on websites and have wondered what they are like... Cheers
Posted : 12/02/2011 3:59 pm
 goog
if you shop around you can get a UPVC for about £350 fitted and a composite for about £550, if you go with a "national company" you'll get stung big time
Posted : 12/02/2011 4:02 pm
This is mine:
Posted : 12/02/2011 5:15 pm
A picture of somebody's front door.
Made my day that.
Posted : 12/02/2011 5:17 pm
My pleasure! But it does go with my post further up the page imploring the OP not to get a uPVC one 🙂
Posted : 12/02/2011 5:54 pm
Thanks guys esp' rockhopper for all important pic!
Posted : 12/02/2011 6:28 pm
I paid £680 for a composite door with a glass panel above it just before christmas, think it is a bit cheap as next door runs his own company and he did it.
Posted : 12/02/2011 6:57 pm
my front door is wood but the rear/kitchen is uPVC and it was about £300 I think, which I bthought was quite expensive at the time but probaly about average. That's unfitted. A mate fitted it as part of a load of other jobs so I don't know how much the fitting bit actually cost.
Posted : 12/02/2011 7:06 pm
just had a composite fitted £845 other thing to remember is they are far stronger than a upvc door plod cannot just kick this one in if they want me for anything
Posted : 12/02/2011 7:08 pm
 mrmo
having sold comp doors for a bit last year, i will try and avoid slagging the lying ***** off too much.
comp doors are better than upvc, but they are not perfect. because they are a composite there is always the possibility of differential expansion leading to the skin delaminating. This is avoidable, if your door is south facing stick to a light colour. Check the furniture is suited, some doors are supplied with unsuited furniture it does save a few pennies but you get slightly different colours for handles and letterplate, which IMO can look a little odd.
Be aware that your guarantee will be with the installer and they have a tendency to go bust with alarming regularity so if anything goes wrong you may find yourself out of luck.
I could also say the mark up on doors is frightening.
As for the police, the police had major problems gaining access to one property with a comp door. Installation matters!!!! i can not stress that enough, there are alot of cowboys, and a badly installed door is likely to cause problems.
You shouldn't need to worry about U values as your dealing with a refurb job, but if you want to maximise insulation use as little glass as you can get away with.
Posted : 12/02/2011 7:25 pm
I'm very interested in this subject, I'm currently looking to replace a uPVC door with composite.
mrmo, what sort of mark-up's are we talking about?
I'm getting quotes of £1400-1500 with a new window (about 4' square, one opener one fanlight) but you can configure a door [url= http://www.compositedoorshop.co.uk/ ][u]here[/u][/url] with a decent spec for about £550, I'm guessing the window I want would be about £300, so that means the local quotes are a bit excessive, but I guess the area I live in doesn't help as there are mainly very big houses that cost mega bucks.
Cheers.
Posted : 12/02/2011 7:58 pm
